Results 1 to 37 of 37
    Non-member Josie172cup's Avatar
    Feb 2009
    Just how bad is it?
    Hi everyone,
    Just how bad is it when your car sounds like its running on spanners. It turns over and starts straight away but the noise is horrific (sounds like a hammer in a washing machine).
    Im no good with car problems i just know that this is not good any ideas what this could be and more importantly how much is it likely to cost.
    Joe
    Non-member benj88's Avatar
    Mar 2010
    Re: Just how bad is it?
    Water pump?
    Feb 2009
    Quote Originally Posted by benj88 View Post
    Water pump?
    i dont think so benj m8 its canny loud and isn't really coming from the water pump i hope your right like
    i'll get a video up tomorrow see what you think
    Non-member modfather's Avatar
    Quote Originally Posted by Josie172cup View Post
    where is the sound coming from do you think
    burton on trent
    is it running ok,.. does the noise change with the revs.. does it do it on idle.. does it do it with clutch engadged and disengadged? maybe clutch/clutch bearing/ gearbox related?
    Mar 2011
    Killer Streets Of Whiston
    if it sounds worse at 1400 revs on just sitting not driving its probly bottom end death rattle if it does it all the time it may be the waterpump or alty mine does the same, i took the belt off and ran it for a min and the noise was gone
    Dec 2009
    west midlands
    maybe something simple one of you ht leads not connected up properly
    Mat
    Feb 2009
    i was half way to work when i noticed so rather than go back i plodded on.
    it makes the rattle when accelerator is pressed. when i let off it stops.
    this is in gear like engine breaking not dipped clutch
    it rattles on idle (very bad)
    the clutch makes no difference.
    as far as i can tell it stays the same with the revs but when i accelerate i struggle to hear anything over the side exit.
    sorry if the above is poorly worded
    i hope this helps you guys a little and i hope it sounds worse than it is.
    Mar 2011
    take the belt off if it still there u can rule out the pump and alty. culd be a piston ring smapped or the tensioner on the chain worn out
    Non-member Junglist's Avatar
    Dec 2008
    Chester
    Quote Originally Posted by peter GT muir View Post
    not for long mind .
    Mar 2011
    yeh only for a min or so or u will end up with a flat batt and a blown gasket
    Feb 2009
    Sorry about the poor quality i didn't have my phone lead so its off a digital camera
    anyways take a look if this works
    http://www.youtube.com/watch?v=ej8zB_C-WMk
    Non-member g10far's Avatar
    Berkshire
    Hard to tell, but to me it sounds like the bottom end maybe? A friend of mine had the same problem and it made the same noise. I wouldnt drive any further if I was you, whatever the problem is.
    Non-member Jonny5's Avatar
    Sleaford
    Sounds very much like a bottom end knock
    Feb 2009
    Quote Originally Posted by g10far View Post
    Quote Originally Posted by Jonny5 View Post
    I got told the same thing but wanted to get a few more opinions.
    Any idea whats involved in fixing this and how much its gunna set me back?
    Mar 2011
    That sounds sweet
    Feb 2009
    That sounds sweet
    please dont laugh
    Mar 2011
    That sounds sweet
    in how u feel my first engine went boom then bought a bottom end off sum 1 else in tonbridge wells rebuilt it only to find one of the rods was slightly bent so it had to come out and get rebuilt again
    Feb 2009
    oh man... how much do you think im looking at to fix?
    Non-member JRP's Avatar
    Nov 2001
    Hogwarts
    Sounds like bottom end.. but really its going to need to be looked at in person up close by a decent in the know member.. anybody local to you?
    Nov 2001
    Hogwarts
    Just realised your in durham, so's Ashy iam sure he wouldnt mind
    Mar 2011
    full set of shells ,crank regrind. oil seals at a min depends on how much u wanna rebuild it you could put new rings, chain etc etc just depends on what u wanna spend. how did it get like that in the first place is also a question could be an oil pump faliure
    Feb 2009
    haha there is a few :P the only problem is it happened on the way to work so its sat in works car park atm, which is 20 miles in the opposite direction
    the night before the oil light came on as i went round a corner so i put some in on the next moning before work and it started rattling on the way to work so i just plodded on and went out to check it at dinner and it was considerably worse, a really heavy knocking.
    Will be looking at a full bottom end rebuild there, sounds bad
    Nov 2001
    Hogwarts
    Let me grasp this, your light came on.. you topped it up? did you check the levels at all? and was the light on long?
    if that light comes on you should pull over asap, a few seconds can be horrific!
    like that show on nat geo.. light indicates seconds from disastor
    birmingham
    with the engine running so hot it will burn oil like anythink.even the simlplest of things not checked on these engines can cause massive problems even checking the oil.dont sound good though pal.every 6 months i change the oil or near to that and 12 months a simple service.
    the things is now that (if it dose end up to be the bottom end)it "could" cost £££do you want to spend your money on it..............?
    Feb 2009
    It wasn't on long i just noticed it out the corner of my eye, not even long enough to see what light it was but the only one near it is the choke light and thats orange.
    Quote Originally Posted by old skool turbo power View Post
    i dont want to spend to much on the engine i rather put something else in?
    typically how much do you think it will cost?
    Non-member Fordy's Avatar
    Aug 2010
    Cambridgeshire
    if you dont want to spend alot of money
    why not just drop the sump off, change the big ends and hope its fine?
    big end bearings, tube of silicone sealer and some oil
    your looking about £60-£70 quid, but its not the best way to do things and probably wont last very long if the crank is scored and the rods gone oval
    Joe, my opinion would be to stick with the C1J and get it right once and for all!! I feel for you mate as you have had a right chew on from the off. Sometimes you just end up with a knacker and it tries your patience. If you still want to do a conversion then the easiest imo would be the B18ft engine and get it complete with all the ecu/wiring etc.
    Feb 2009
    i just feel its going to be one thing after another with this engine and if im going to spend near a grand fixing it i may aswell put something a little better in
    at the minute im trying to get it back from work but after then i need to figure out what im going to do as im using our lass' car atm
    Non-member TNT ANDY's Avatar
    Jeepers - £1000 to fix a bottom end (if that's what it is???) Seems a lot to me. Are you not planning to do it yourself? even so £1000 seems a tad over the top.
    Shells - £60
    Head gasket - £60
    Crank re-grind - £100.
    I've still got £720 to play with.
    Feb 2009
    Shells - £60
    Head gasket - £60
    if i was to get it rebuilt i'd be needing to use it quick as its my daily driver so it would involve paying someone else to do the work. i have no idea what that will cost. or where i can get it done.
    if i where to go down the other route i would get another cheap car so i had plenty of time to work on the 5.
    Doing a rebuild is easy you can have it done in a weekend and thats including removing engine out of the 5 and putting rebuild engine back in. Should still leave you with plenty of time spare for tea, coffee, food, and setting the ole girl up but you need to have all parts ready to go in.
    Also check the oil pump tolerances swell as you don't want to rebuild and have an oil starvation problem again.
    If you need I have a decent crank and decent spare oil pump
    Do a comp test before you strip it down as oil problem could have been down to rings?
    burton on trent
    you could just pic up a used working bottom end maybe..
    personally id just repair any damage and get it back together.
    all hail the cheapo c1j
    Feb 2009
    Quote Originally Posted by modfather View Post
    ^^ lol
    at this time i think its going to be better that way.
    im going to ring a few garages as i dont think i have the knowledge to be able to do this quickly
    ^^ lol
    Don't get a garage to do it they will just take the piss, what you need is a localish member whom can do it for you or give you a hand and help you do it
    Have a word with your local are rep and see if they can help if not they may know another member up your way whom would be happy to do it for you.
    Shame your so far up north there are a few members down this way whom are would be more than willing to help
