Not seen a group buy in a while.
Would these be much interest in a group buy of poly flex bushes, im sure we could find a supplier willing to sort us out a discount if ordering a large number. ?
I would be into this.....
What sort of price does the kit normally retail at? ..... (sorry Im using my phone, its too much hassel to search )
you can get them for around £3 per bush anyway??
doesnt mike do the superflex kit for around £60?
£3 per a bush ?, where from, that well cheap.
I would buy one front set of bushes
interested if we can get this to go through at a reasonable speed.
They seem to have gone up since i bought some last,but still cheaper than the others available.
http://www.rallydesign.co.uk/product...f34lbm046qavg1
Im not very good with group buys but i wonder if maybe mike would be able to do us a deal on teh kits based in a min order?
speak of him and he shall appear, Would it be easier to order full kits or would individual sets (roll bar bushes), (Wishbone bushes) seperate be possible.
We will get the best deal on full kits. If we can get numbers together I will make a few calls and see what price I can do them inc the p&p.
Thanks
Mike
Sweet .. well the list now begins.
Djinuk - Full Kit
Djinuk - Full Kit
tubbyG - Full kit
Djinuk - Full Kit
tubbyG - Full kit
FSP- Full kit
how hard is it to fit these??
very easy i beleve..
Basically remove wishbone, use a burner to set fire to the bushes in there, then use a hacksaw you cut out the outer sleeve and drive it out, then pop teh new ones in.
I dont mind putting together a guide if you like.
Might need to weld the sleeves in place, don't forget to measure the bush spacing, otherwise you can get a difference in caster from side to side.
Mikes ones don't come with sleeves. The power flex ones do though and it's not a necessity to weld the unless your using it for track.
Marc@pissyellow
Djinuk - Full Kit
tubbyG - Full kit
FSP- Full kit
Blunty - Full kit
You're going to need to select harder or softer bushes. Harder being the red 'race'. Soft being the yellow 'sport'.
I fitted race. They are not easy to fit into the subframe. With a Dremel I ground the edges off of the subframe fitting areas (for want of a much better description!) so they (fitted to the wish bones) could be hammered in with a rubber or wooden mallet, or maybe I used the 8lb persuader via a wooden plank off cut. Either way, it took a bit of time and patience.
i know when i bought my power flex kit i got the full kit for £79 inc vat at larkspeed leeds
Djinuk - Full Kit
tubbyG - Full kit
FSP- Full kit
Blunty - Full kit
TNT Andy - Full Kit
Daz5774 - Full Kit
any body else
As long as price is good I'm in.
Djinuk - Full Kit
tubbyG - Full kit
FSP- Full kit
Blunty - Full kit
TNT Andy - Full Kit
Daz5774 - Full Kit
DavemayGTT - Full kit
Djinuk - Full Kit
tubbyG - Full kit
FSP- Full kit
Blunty - Full kit
TNT Andy - Full Kit
Daz5774 - Full Kit
Big Steve - Raider - Full Kit to suit an 11 Turbo (Think it's just the same as a Phase2 GTT kit anyway?
Ok, I have made a few calls and got another account setup. I can offer Powerflex or Superflex items. We need to get an order of ten together and then will can get a good deal.
Thanks
Mike
I imagine the cheapest will get the majority vote
i've got the full red kit on my 5
the only problem i had was getting the arb brackets back on i did it with the subframe in situ
the red bushes dont compress at all which makes for alot of swearing when fitting
im interested but id like to know the price before committing.
Right, Powerflex as Marc pointed out come with the sleeves and offer many different sizes, where as Superflex only offer the Phase 2. What I need to know is the size and and amount of to get the discount sorted. My online account has been setup so we can get moving. If we get 10 orders we should be looking at a decent discount.
http://www.powerflex.co.uk/products/...rbo-126/1.html
Thanks
Mike
hi mike,
bit of a hi jack but I've talked about this on the boards before but think it might get a few more eyebrows raised here.
seeing as you now have a contact within power flex it might be something you can arrange, rear trailing arm bushes, i was under the impression that power flex would be able to make these if there was enough interest and they had a new bush to copy, which i didn't have access to when i was making enquires
maybe next time you talk to them you could see where they stand on this now and gauge interest from what they can do
nick
it may be worth investigating as mine failed it's mot because of perished bushes hence why i looked into it without much luck, ended up with a second hand beam as the cost for new bushes from renault was crazy
maybe if it's a viable option we could get the club to buy a bush for them to copy and they could get the money back selling sets in the shop like the dials/manifolds ?
Interested in rear bush if this comes about
I'm interested in getting rear bush set too
Djinuk - Full Kit
tubbyG - Full kit
FSP- Full kit
Blunty - Full kit
TNT Andy - Full Kit
Daz5774 - Full Kit
Unstablecable -full kit (depending on cost )
giving this thread a bump as it seems like only me and mike are going through with the purchase now
I am keen to get an order done today if possible. I need the sizes, please have a look at the website. Once we have numbers we can work out the discount.
Thanks
Mike
not 100% sure but if these kit includes the arb bushes ,might be worth having words about the 11 turbo(big steve). pretty sure the brackets/bushes that bolt the arb to the the subframe are different to the 5 gtt, remember having difficulty finding some for my rear subframe(ren 11 also). renault were'nt much help either, was told they stopped making them/and have none left in stock,and cross referenced with another part number,which did'nt fit either renault 19 springs to mind anyway just my 5 pence worth
Anything new about this?
any idea what size arb bushes im going to need ? phase 2 J reg, issue is the cars at the bodyshop
For details of where to measure please read and look at the picture.
Thanks Mike
Im really sorry mike but im just not going to be able to commit until ive got the car back to measure up , im really sorry to mess around dude.
Id like to know more about the rear bushes and if it would actually be possible to get them made up,my front is already poly'd up you see and id like it all round :-),i personally think that if it was achievable then most members would buy a set due to the crazy price renault want,mike work your magic mate:-).
