calling all experts
got 99% done on the 11, but one last issue....
hunts on idle badly, even with a group A dumpvalve its still pressurising the boost circuit on idle, blowing air out the dv...
can't get it to run properly, when all the vac pipes off the inlet are connected it stutters and idle drops, if i put a one way valve on one of the pipes and leave it open to atmosphere idle is better
kinda hard to explain, but its almost like it needs more air in the inlet manifold for it to run, and by pulling a pipe off the inlet it sorts it, but surely i'll loose boost when its running
i disconnected the ICV and it revs its nuts off, plugged back in and its sitting at 1000rpm with vac pipes off, and about 600rpm with it all connected, but hunts and cuts out after 30 secs...
anyone got any ideas? this is the final hurdle
