I've been having a crack at making a Throttle Cable Linkage (for the cable conduit to push against), something I had forgotten all about
![Ashamed](images/new-smilies/ashamed.gif)
I might be able to combine the boost hose adaptor but not sure? Open to suggestions.
I made it out of 7075 T6 that I had some offcuts of at work. Not Finished yet but a start. This is the plate with a couple of angles out on to it for stiffness.
This is the plate sitting on the Throttle Body
Here you can get an idea of where the cable will run
The throttle cable will run through a hole somewhere in the corner with the aid of a few bicycle brake parts
I'll get some more pics up as it progresses.
![Big Grin](images/new-smilies/biggrin.gif)
