Hi Guys,
Right the adaptronic unit has been installed now and I've had it running ignition only (not mapped) for some time and the car has started every time and strobbed correctly. I have recently changed my flywheel sensor to a 36-1 trigger wheels jobby and one of scoffs sensors. I can't get the thing running right. I have used the wizard in Wari to set up with no luck. The wheel has been positioned on the crank so that the missing tooth is approximately 90 deg BTD and the sensor has been temporarily wired useing trigger wheels 2 core + shield cable but the shield has not been connected to ground as I don't know how to do this or really which where to connect the sensor to on the 420b.
Any ideas???
