It seems i have maybe got my timing a little out on my new engine build, engine is in and struggles to start / does't really start . I decided to do a comp test to see if the valves where to blame, only tried one cylinder but i only got 90 psi, this is with new pistons, liners and rings so im guessing my timing is retarded like me after reeading a recent thread.
The cam is a msm one and its timed correct to the cylinders ie valve 1 and 2 move with comp stroke and exhaust stroke of cylinder 1.
Engine turns over great with no plugs in but with the plugs in it really struggles.
I took the rocker cover off and while it was in the car hooked up a protractor and a pointer, i brough the fly wheel to tdc so inlet was the next valve to open, i set the pointer to tdc on the protractor and unfortunaly i dont have a dep gauge? its elsewhere at the mo but by feel and sight then moved the bottom pully round, the inlet valve stops moving at 112 atdc but then moves again around 130 atdc so im guessing im timed in at around 121 atdc would this equate to roughly 1 tooth out on the vernier? also at tdc the dis points off parralel slighty not over amounts but noticable, any ideas people of what i can try would be greatly aprecciated .
with thanks ross
