getting fuel and spark also vacume hose rom aei is in correct connector. perhaps put my dizzy drive gear on back to front, can only think that could be the problem. also trying to start with alternator off
Whats it doing eaxctly mate?
just spluttering, sounds like it wants to go thougt. may be i have put the drive gear on at the falce tdc
give it a go in the morning. every thing seems perfect think it can only be that thanks
valve clearence???????????????
plug lead order????????????????
money is on drive gear being out!
Have you put new plugs in it if so check the gaps if you have set them to much this would also cause your problem. But it does also sound like your dizzy gear is out or your plugs are not correct for your firing order
