With you there Karlos.
Going off what he's experienced and researched, he should be getting close to what he want's.
Which is a small blue sideways coffin
Lmao, - feel the love in the east coast massive tonight!
clutch / gearbox / driveshfts going in this weekend....it will be 85% complete again
made a start yesterday, engine and gearbox now back together with clutch in was a pain to fit even with the engine out the car, word of advice , if anyone else is doing this conversion in the near future , remove the drivers side drive shaft output flange first before trying to line up the gearbox to engine
all mounts finished and painted and in place along with modified thermastat housing,starter motor and gearbox selector rod connectors , stripped rocker assembly and removed old cams and cam belt, fittting new cams/belt /tensioners sunday along with the new driveshafts with some help from the wise bearded one
so wen is the car driving again?
pics?
Good work Andy
Must have been out of the loop for too long, someone has grown a beard and is considered to be wise
hopefully tuesday night will get some pics up, the egt/air temp gauges turned up yesterday, so might fit that as well if i have enough time
exhaust system and screamer pipe system should be finished by end of next week also
Looks great! What turbo is it?
Looks like a gtx because of the 11 blades however it isn't a gtx cover...
must have been way cheaper then my gtx3071r then?
although you shouldn't forget the geometry of the gtx wheel is different than the gt wheel so the housing is probably sh*t on it....
Thats an awful lot of effort to blow up a glove.
Wow thats a big turbo its going to sound awesome spooling up when its two feet from your head
Niceone Andy, - am thinking meet up when shes done with the usual suspects?!
I'm thinking of a Crimbo Doo.
Maybe a meet up in Cambridge to get southern members involved also.
See
https://www.rtoc.org/boards/showthrea...769#post293769
C'mon MoFo - Update please.
formed new turbo oil return pipe back to sump, for the new turbo position ,(15 mm copper pipe and bender,and 2x copper olives for the swaged ends)
wired in the new starter motor,fitted the hydro pipe to the clutch cylinder/ release bearing,(m10x1.00) for future reference if anyone else goes 02m route
also fitted the header tank, coolant hoses for the rad (pain in the arse,getting it to clear the gear selector arms/bracket) turbo and wastegate, also fitted the 350cc injectors to the first fuel rail (closest to the cylinder head) and fitted a new tow eye bracket and seatbelt type tow strap the tow eye bracket is part of the front box section/slam panel where the subframe bolts up,and fits neatly between the air intakes in the bumper front splitter has covered over the o.e tye bracket and position
Tim is taking the car up to his workshop today,so hopefully by the end of this week the manifold and exhaust system will be complete
getting there
decided to run the wastegate and exhaust seperate to each other , i know we spoke about this a few weeks ago, and the sound of a screamer pipe sounding like poo!!, but i still dont think it will be a big problem in my case as the exhaust is loud anyway and being only 1.5m long in total length and with the engine being fairly close to the seating area well you know what im getting at,
the waste gate pipe will run along side the exhaust system and both will then be joined together where they exit the rear bumber , should look very nice ,and have less flow restrictions/turbulance issues to overcome
been busy buying more bits for the beast, bought a few m6 rose joints and rods for turbo bracket support/ bars, two poly x exhaust mounts and another load of fuel lines/connetors/ in line filter for modifiying the existing fuel system with the exhaust /wastegate system is looking good and is 95% done, and have been designing /building a release handle for my new compbrake handbrake system, so i can engage release with one hand, without having to mess about and take my eyes of the road, so to speak , i have also got to build a heat shield for drivers side drive shaft inner rubber gaiter, as it sits fairly close to the runners on the exhaust manifold and will no doubt burn/melt in time sending grease all over the manifold and resulting in a ball of flames,
looks like im going to be busy for a few more weeks/months yet
**** that'll be a laugh in the wet...
wooooooooooooooosh,,spiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiin....Hopefully change, and again wooooooooooooooooooosh,,spiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiin hopefully change........
Qtr mile time N/A...
Kwick fit "trade" account..........................most definately applicable
Top Job fella
Just read through the spread in PPC on this again, and was thinking how much it's changed since that how's it coming anyway?
will get some pics up later today
my computer skills fail
up loaded photos to photobucket, but from there cant/wont transfer to the rtoc site,anybody got an idiots guide on how to upload
Just copy the [img]url[/img] link below the pic and paste it here.
here is a few piccys of the wastegate and exhaust system,still got a little bit of work to do
here is a few of the the engine bay with the pipe work dummy fitted so to speak, still need to fettle abit with the layout
here is a few of the new hydrolic handbrake, had to ditch the old set up, as the new gear selector system got in the way of 2nd and 4th and sixth
here is the new exhaust pipe layout
and finaly a few shots of the outside of the car, its not been cleaned in months and has a few issues with movement cracks on the kit, but will sort theses out next year
and some more shots of the front splitter and connards
got lots more to do, like getting rid of the ****e fit carbon bonnet, got a nice 16v fibreglass item to fit, not everyones cup of tea also will be re fitting the phase one grill
and get rid of the scoops as they dont look right, already started making new items,but with horizontal slats like the original skeete type
and a general tidy up over winter along with a gauge sort out,knock sensor to fit ,air/exh temp gauge, and maybe meth injection to go in
Finally some progress pics Can't wait to see it in the flesh next year!
Where do you get the intake air from?
Outstanding project mate really does look amazing and I'm quite jealous actually it's making me want to start another project, I really can't wait to see this next year great work mate
Phil
Car looks fantastic mate, those image rims really suit the car well I'll be honest this is inspiring me to start my project and finally get the ball rolling.
I think the 16v bonnet will look good, where did you get it from?
Great work Andy, - been busy then! look forward to seeing her finished
Give me 1st refusal on the ****e bonnet ;-)
thanks for the great comments guys, still got lots to do, will get more piccys up over the next week or so, thinking of carbon wraping the 16v bonnet or maybe painting it blue, thoughts on that anybody
carbon bonnet will be coming of in the next three weeks
cough cough mr B
