Page 5 of 6 FirstFirst 123456 LastLast
Results 201 to 250 of 271
  1. #201
    Sep 2009
    meath
    Re: my ginger mobile, from start to present... pic heavy!!
    is your arse having a love affair with your thumb?
  2. #202
    Nov 2010
    Burntwood Staffs
    have you got any videos of ginge in action mark?
  3. #203
    Non-member markey b's Avatar
    Bury St Edmunds
    Quote Originally Posted by jamie_clioGTT View Post
    dont think there are many, search 'wsmcuk' on youtube may be a couple
    just purchased my nodiz ignition unit (www.nodiz.co.uk) so that should keep me busy over the winter months
  4. #204
    Sep 2009
    meath
    are you not going to go full efi?
  5. #205
    Bury St Edmunds
    Quote Originally Posted by robx1r View Post
    na no point i only use it for 30 miles a year
    that brake tank on carters was a custom made one by the way, carrera made it for him
  6. #206
    Sep 2009
    meath
    ah bollox, are they still in buisness?
  7. #207
    Bury St Edmunds
    not a very exciting update, just some deliveries
    cars been in garage since july i think, better go and check on it sometime soon!
  8. #208
    Bury St Edmunds
    more parts ready to fit...
  9. #209
    Bury St Edmunds
    tomorrow is the day!
    going to tax the old girl tomorrow as MOT runs out 16th march, got it booked in for a fresh ticket next sat, so i'll pick it up from its garage after work and get it to the chop shop for new blower, then get it mot'd, then the fun can start
  10. #210
    Norwich
    Niceone mate, hope you manage more than 30 miles this year!
  11. #211
    Bury St Edmunds
    had a productive eve... new turbo and manifold on, manifold braces taking shape (cheers ipswich ) rebuilt the carb and then started to get stuff fitted up for the nodiz
    well impressed with the efi parts trigger wheel kit, perfect fit minimal fuss!
    some pics...
  12. #212
    Jun 2011
    pwhoarrrrrrr....some serious 5 porn there mark ;-);-)
    very impressive mate keep up the good work mate...loving it !!!!
  13. #213
    Member Woznaldo's Avatar
    Canberra, Australia
    Nice work Mark, I can also confirm that the EFI-Parts C1J Bracket and Sensor are a no brainer easy fit bit of kit.
  14. #214
    Bury St Edmunds
    passed its MOT on sat, 54 miles since last one haha
    now its got a decent ammount of t&t, i've started to crack on with the nodiz
    got some of the loom in, took ages to work out where everything is going, then route the loom, then get it all to length then do all the looming, heatshrinking etc. should make it easier to do bits in the future tho, as the nodiz loom is connected to the car loom via another plug so in theory it'll unplug the whole lot if need be
    just waiting for my HT lead kit and a few other bits and bobs that i oversaw to arrive, then should have it fired up again in a few days
  15. #215
    Dec 2011
    Really intrested in this keep us posted with plenty of pictures car looks great btw
  16. #216
    Sep 2009
    meath
    How did you sort out the dizzy?c
  17. #217
    Bury St Edmunds
    chopped a spare up with a grinder, then pulled the 'shaft' out the middle and cut that down even more, grinder on the top to make it smooth, then put the shaft back in so it keeps the dizzy drive down running the oil pump, then couple of washers instead of the bracket and bolt back on
  18. #218
    Sep 2009
    meath
    Like lobbed the top off it l?
  19. #219
    Bury St Edmunds
    literally, it was trial and error, and it seemed to work. may get the hole alloy welded if oil seeps up, if not i'll just make a lill carbon fibre disc and silicone it on to cover it
  20. #220
    You and your bits of carbon fibre
    Nice work though
  21. #221
    Feb 2011
    Carshalton, Surrey
    looking forward to seeing how the Nodiz kit works. its going to be a few months till i can get mine up and running.
  22. #222
    Feb 2012
    Nottingham
    Quote Originally Posted by Jeff Ninebar View Post
    Has anybody actually got this running yet?
  23. #223
    Bury St Edmunds
    I've had it coughing this eve, need to set up tdc on trigger wheel properly though
  24. #224
    Bury St Edmunds
    few pics of this evenings efforts... wiring all sorted now
  25. #225
    Non-member TNT ANDY's Avatar
    Once you have a rough idea where the missing tooth is in relation to TDC, using the trigger wizard, set up as follows (I'm assuming you are using a 36-1 wheel):-
    1- select Triggering Tab
    2 - Select trigger settings
    3 - Select setup wizard
    3a - Select 36 missing teeth on the Crank.
    4 - select 4 cylinders
    5 - select '90' btdc
    6 - select '1' under missing teeth
    7 - Select missing tooth crank
    8 - Select batch
    9 - Select coil pack.
    Once all that's in, disconnect your fuel line to your carb. Go back into the trigger tab and select lock trigger timing and adjust to 10 deg. Strobe on the flywheel to see if your timing mark hits the 10 degree mark. If not, use the offset trigger angle buttons to get it to line up. once you have a match, unselect 'lock timing' and you're done. BTW the 10 degree timing mark is the one nearest the passenger.
  26. #226
    8 - Select batch
    That would be if you where on Adaptronic
  27. #227
    Bury St Edmunds
    All running now :-) phew
  28. #228
    Non-member Logg's Avatar
    That's excellent news well done. when's mapping start?
  29. #229
    Bury St Edmunds
    mapping will start once my bank recovers
    almost there now, made up some new HT leads, fitted new rad with fan on front to free up some space, braced the turbo and sorted CTS sensor
  30. #230
    Erm where's that screamer pipe aimed?
  31. #231
    Bury St Edmunds
    Waiting for the new one so it can be moved down into the arch lol
  32. #232
    Was gunna say, your bonnet will be in a right mess like that
  33. #233
    Dec 2011
    Really nice work the car looks great
  34. #234
    Bury St Edmunds
    Little update, drives beautifully on the nodiz, seems to be much better off boost even on 'renix' basemap ;-)
    Also had a screamer pipe made up by my talented brother :-)
  35. #235
    Feb 2011
    Carshalton, Surrey
    Mark, I just noticed on your thread on the Nodiz Forum you mentioned that the R5 Rev gauge doesn't work, is this from removing the AEI that it now doesn't get a signal?
  36. #236
    Bury St Edmunds
    Kinda, I just ran a couple of diodes from the coil trigger wires, into a Zener diode then chipped into standard rev counter wiring at aei plug :-)
  37. #237
    Feb 2011
    Carshalton, Surrey
    ah ok, but I take it that didn't work?
    I was looking at the user guide for the Nodiz and it says there is an output for a rev counter from the Nodiz Electronic module, have you tried using this at all?
  38. #238
    Non-member gttjames's Avatar
    Cambridge
    mark what rad fan are using - as if im going to use my new rad il have to get a front mounted cooling fan - what can be used easily?
  39. #239
    Bury St Edmunds
    No it works with the diode method, I've got a couple already built on ebay if u search 'nodiz' on there :-)
  40. #240
    Bury St Edmunds
    Quote Originally Posted by gttjames View Post
    Spal one fella, was on the rear but putting it on the front frees up room for the screamer pipe run :-)
  41. #241
    Bury St Edmunds
    54 miles this year.... Release bearing failure already. Amazing!
  42. #242
    Non-member GTphil's Avatar
    What a pisser! Nothing worse than pulling it out of hibernation for it to break within a few day!!
    engine back out now then
    I suppose its quite normal for you now
  43. #243
    Lol, that's because they are not designed with an elliptical motion in mind.
  44. #244
    norwich
    at least youve broken the 30 mile barrier already on its first outing, infact you almost doubled it, which is still more than mine will prob do this year
  45. #245
    Stop being such a tight Arse HAndy and get on with it
  46. #246
    Not sure you're getting this, so I'll elaborate a little.
    Now I think it's fair to say, I'm not the most competent person on here. But when you put the gearbox off, accurately measure the flywheel for the true centre of your cover plate. Your mate who mounted mine made a right arse of it costing me the flywheel and £50 for ****ing it up. Looks like he may just have contributed to your short comings.
    Then again, it might be something totally unrelated, but clutch release bearing probably dont like to wobble about on untrue things.
  47. #247
    Bury St Edmunds
    I haven't had it apart yet cos workshop is full of other people's cars, bike broke too so wasn't te best long weekend lol
    I'll measure the flywheel but when mine was drilled I drilled thru the old one so it will be exactly the same as the one that turbo ted used if that makes sense
  48. #248
    Bury St Edmunds
    Slight update.... Fixed the bike! Car still outside thinking about what it's done however... Naughty car!
  49. #249
    Bury St Edmunds
    And it's back... Any bets on what breaks next? Big thank u to ipswich for the helix :-)
  50. #250
    norwich
    did you change your wobbly off centre flywheel
    if not, im going to say clutch again, or gearbox
