21 - Manual Gearbox - Gear Selector Fork
1 - 77 00 104 811 (7700104811) - COVER SELECTOR LA - £5.79 - Still Available 07/10/15
2 - 77 03 087 163 (7703087163) - CAP SELECTOR - £8.58
3 - 77 03 067 030 (7703067030) - ROLLPIN LE - £0.32
4 - 77 03 067 137 (7703067137) - ROLL PIN LE - £0.32
5 - 77 00 648 234 (7700648234) - PIN SELECTOR FORK - £0.63
6 - 82 00 177 390 (8200177390) - FORK SELECTOR - £6.62
7 - 77 05 015 138 (7705015138) - SPRING S/FORK - £2.31
8 - 77 03 090 215 (7703090215) - BALL BEARING - £1.27
9 - 82 00 236 007 (8200236007) - SELECTOR FORK - £64.83
10 - 77 03 067 313 (7703067313) - PIN STG/SHAFT - £0.31
11 - 77 00 725 720 (7700725720) - FORK CLUTCH N5 - £24.53
12 - 77 00 875 584 (7700875584) - LINK G/BOX LE - £21.03
13 - 77 00 859 626 (7700859626) - GAITOR - £4.66 - Still Available 07/10/15
14 - 77 00 859 626 (7700859626) - GAITOR - £4.66 - Still Available 07/10/15
15 - 77 00 114 806 (7700114806) - SHAFT G/LEVER - £117.4
16 - 77 03 066 329 (7703066329) - CIRCLIP - £0.45
17 - 77 00 648 232 (7700648232) - PIN SELECTOR FORK - £0.32
18 - 77 00 736 437 (7700736437) - PLUNGER SELECTOR - £0.63
19 - 77 00 850 699 (7700850699) - FORK 5TH R19 - £52.75
20 - 77 03 067 312 (7703067312) - PIN STG/SHAFT - £0.31
21 - 77 00 736 438 (7700736438) - PLATE SEL R19 - £0.47
22 - 77 00 715 851 (7700715851) - STOP CLUTCH FORK - £0.59
23 - 77 00 872 205 (7700872205) - BUSH SELECT R19 - £1.11
24 - 77 00 872 205 (7700872205) - BUSH SELECT R19 - £1.11
25 - 77 00 104 813 (7700104813) - STOP GEAR 5TH - £6.18
26a - 77 03 053 605 (7703053605) - SHIM (X) dimension = 0.33 - £0.49
26b - 77 03 053 606 (7703053606) - SHIM (X) dimension = 0.66 - £0.49
27 - 77 00 872 205 (7700872205) - BUSH SELECT R19 - £1.11
