21 - Manual Gearbox - Gearbox Gears Page 1
1 - 77 00 112 232 (7700112232) - SHAFT SECOND. C2 - £208.25
2 - 77 03 090 323 (7703090323) - BEARING AUTO GBOX - £25.25
3 - 77 00 865 188 (7700865188) - GEAR ME - £95
4 - 77 01 644 802 (7701644802) - SYNCHRO GEAR N5+ - £80.1
5 - 77 00 872 114 (7700872114) - GEAR 2ND N5+ - £99.18
6 - 77 00 740 877 (7700740877) - GEAR 3RD N5+ - £72.13
7 - 77 01 463 612 (7701463612) - HUB ASSY G/BOX - £144.17
8 - 77 00 685 833 (7700685833) - SPRING SYNCHRO - £2.86
9 - 77 00 737 092 (7700737092) - CLIP SYNCHRO R19 - £1.95
10 - 77 00 667 703 (7700667703) - ROLLER SYNCHRO - £2.76
11 - 77 00 708 152 (7700708152) - SYNCHRO RING - £32.09
12 - 77 03 066 376 (7703066376) - CLIP G/BOX - £1.8
13 - 77 04 000 446 (7704000446) - RING GEARBOX - £1.42
14 - 77 00 864 003 (7700864003) - GEAR 4TH SPEED - £72.13
15 - 77 00 115 628 (7700115628) - RONDELLE APPUI - £3.19
16 - 77 03 066 384 (7703066384) - CIRCLIP S/SHAFT - £2.23
17 - 77 03 090 553 (7703090553) - BEARING GEARBOX - £22.33
18 - 77 00 858 307 (7700858307) - GEAR 5TH FIXED C2 - £72.13
19 - 77 00 870 777 (7700870777) - £(not in price list)
20 - 77 00 110 614 (7700110614) - THRUST WASHER C2 - £1.8
21 - 77 00 866 290 (7700866290) - BUSH G/B - £10.46
22 - 77 03 090 312 (7703090312) - BEARING GEARBOX - £3.05
23 - 77 00 858 308 (7700858308) - GEAR 5TH 41T N5+ - £72.13
24 - 77 00 656 205 (7700656205) - SPRING GEARBOX - £2.86
25 - 77 01 637 670 (7701637670) - HUB G/BOX R19T - £80.1
26 - 77 03 034 082 (7703034082) - NUT - £1.5
27 - 77 01 469 748 (7701469748) - SHAFT CL - £126.22
28 - 77 00 720 240 (7700720240) - SLEEVE GEARBOX - £1.6
29a - 77 00 647 358 (7700647358) - BOLT TN 1699 (X) dimension = 28 - £0.69
29b - 77 00 723 507 (7700723507) - BOLT GEARBOX (X) dimension = 42 - £10.23
30 - 77 01 462 576 (7701462576) - CLIP SET G/B - £3.8
31 - 77 00 874 078 (7700874078) - END CAP S/SHAFT - £3.02
32 - No reference chosen for this vehicle
