11 - Upper Engine - Valve Timing
1 - 60 01 006 496 (6001006496) - £(not in price list)
2 - 77 00 525 087 (7700525087) - PLATE - £6.82
3 - 77 03 001 118 (7703001118) - BOLT 6X12 NT1986 - £0.5
4 - 79 03 056 008 (7903056008) - WASHER - £0.47
6 - 77 04 001 718 (7704001718) - SPACER C/SHAFT R9 - £2.32
7 - 77 00 655 335 (7700655335) - SPROCKET C/SFT R5 - £32.98
8 - 77 03 101 069 (7703101069) - BOLT 10X30 - £0.69
9 - 77 03 053 345 (7703053345) - WASHER - £1.6
10 - 77 00 722 758 (7700722758) - CHAIN TIMING 11 - £15.09
15 - 60 01 008 124 (6001008124) - £(not in price list)
16a - 77 00 690 122 (7700690122) - TAPPET BLOCK 4 (X) dimension = 19.00 - £19.5
16b - 77 01 462 573 (7701462573) - (X) dimension = 19.20 - £(not in price list)
17 - 77 01 462 385 (7701462385) - VALVE IN SET R11T - £50.4
18 - 77 00 509 768 (7700509768) - WASHER - £0.47
19 - 77 00 655 195 (7700655195) - SPRINGS VALVES - £4.95
20 - 77 00 512 368 (7700512368) - CAP VALVE SPRING - £6.15
21 - 77 00 564 113 (7700564113) - COTTER I/VALVE 19 - £1.43
22 - 77 01 463 181 (7701463181) - VALVE EXH SET 11T - £50.4
23 - 08 54 895 300 (0854895300) - COTTER EX VALVE - £1.43
24 - 77 00 723 029 (7700723029) - PUSH ROD - £6.3
25 - 77 00 651 640 (7700651640) - POST ROCKER R18 - £10.86
26 - 77 03 058 054 (7703058054) - £(not in price list)
27 - 77 03 032 062 (7703032062) - NUT - £0.36
28 - 77 03 002 302 (7703002302) - BOLT 7X55 - £0.69
29 - 77 00 711 355 (7700711355) - £(not in price list)
30 - 77 03 066 313 (7703066313) - CLIP - £0.54
31 - 77 05 015 264 (7705015264) - £(not in price list)
32 - 77 00 710 231 (7700710231) - ROCKER ARM R18 - £15.53
33 - 77 00 710 232 (7700710232) - ROCKER ARM R18 - £46.77
34 - 06 07 281 700 (0607281700) - SCREW TAPPET N5 - £1.7
35 - 06 07 153 700 (0607153700) - £(not in price list)
36 - 77 00 719 076 (7700719076) - CHAIN TENSION 4 - £24.29
37 - 77 03 001 125 (7703001125) - SEE 7701405663X20 - £0.41
38 - 08 57 538 200 (0857538200) - £(not in price list)
39 - 77 00 521 452 (7700521452) - £(not in price list)
40 - 77 00 521 450 (7700521450) - £(not in price list)
41 - 77 00 564 398 (7700564398) - PINION DIST CL - £46.18
