Compression test
I did a compression test yesterday night, results:
From flywheel, dry test
1- 170psi
2- 140psi
3- 145psi
4- 160psi
Wet test
1- 180psi
2 -145psi
3- 160psi
4- 165psi
Any cause for concern? As the middle 2 are a little lower than the outside 2!
Committee, NW Regional Rep
Re: Compression test
The middle 2 do seem a little low compared to the others but they're not LOW as such. If it's running well I wouldn't worry too much, get it to ND and give it hell!
Super Administrator
they should be around 145 mate mines are all that after rebuild is the head ok not been over skimmed as mikes old engine had 170/180 and it kept blowing hg due to over skimmed head boss
Yours has a cam though so will be a little bit lower
