Results 1 to 11 of 11
    Jul 2013
    fuel pump
    not so long ago I put up asking about why I was leaning out high up the rev range (a sudden leaning off)
    never done this before, I whipped the carb off and gave it a ggod clean, which seemed to have resolved the problem.
    but after going out a drive at the weekend it was doing it again then all of a sudden juddering and starved of fuel.
    so fuel pump must be knackered not giving me fuel pressure, however I replaced the fuel pump/filter last year so why would it give up so soon or is their anything else to check?
    fpr is in good working order?
    my tank was running low not empty but low would this make it difficult for the pump to pick up fuel?
    Mar 2013
    Re: fuel pump
    do you get any spluttering and holding back at all at certain revs ?
    Jul 2013
    Re: fuel pump
    yes before it was spluttering and holding back once boost had kicked in now running crap all the time
    Dislikes Ryan250 disliked this post
    Norwich
    Re: fuel pump
    When fuel low the aux tank transfers the reserve amount into the main tank (light illuminates). What jets are you running in the carb? is the accelerator pump working correctly?
    Dublin/Ireland
    Re: fuel pump
    there is a pic-up filter in the tank!
    Mar 2013
    Re: fuel pump
    does it idle ok at all ? and does it only splutter / hold back when boost kicks in
    also did it just start playing up or after you changed something ?
    Re: fuel pump
    What boost are you running and what are the AFR's at WOT when it starts leaning? You might emptying the fuel bowl. You can check the fuel pressure by tapping into the line, it should be about 4psi at idle and remain at 4psi above boost pressure. i.e. if you run 15 psi the fuel pressure should be about 19 psi.
    Jul 2013
    Re: fuel pump
    idle ok
    not changed anything
    15 psi
    ran slightly rich high tens all through rev range
    I think ill try dizzy leads and plugs first just to rule that out then go onto fuelling
    cheers
    Jul 2013
    Re: fuel pump
    at the start it was only spluttering once boost kicked in now all the time
    Re: fuel pump
    High 10's is quite rich. I'd be looking into the jetting. Do you know what jets are in the carb?
    Yes, worth checking or changing the dizzy/rotor and plugs
    Mar 2013
    Re: fuel pump
    im having the same prob as you mate ive changed dizzy plugs rebuilt carb new fuel relay aei unit but she still splutters when coming on boost arount 3/4k been baffled for months now
