I think I have some 0.48 cosworth housings if you wanted to play lee. I also have an old T04B cover, wheel and backplate that will be good for over 300hp (going cheap) if you wanted to build a budget unit for the new engine![]()
just to add, finnished off my own turbo's rebuild today, thankyou to Adam L for sorting a 360deg bearing kit. it now works fine again with no shaft play. I melted 2 270deg bearings last year - the back's of them in particular. guess that was too much thrust for them to deal with.
Got a new Cossie 2wd .42 Compressor if anyone wants to swap for a .48 4wd Compressor![]()
Cheers Scoff .I will take you up on that
I'll get Adam to rebuild the bits he has there and then I can play about with the hot end ..
