Hi Guys
I believe I've read about people who have painted their ph1 body kit with a textured paint that gives a finish similar to the black unpainted OEM finish? Can anyone point me in direction of which paint to use?
Kind regards
Dennis
Hi Guys
Kind regards
Dennis
Dennis. I've used halfords textured paint, then paint on top with colour. The halfords stuff needs rubbing down or the texture is too sharp. It's not a bad match.
Thanks a lot mate. What did you paint on top with? Just satin black?
No mate. Renault have an actual colour match for the various phase 1 bumpers. I know mine is a Renault 612 gris. I imagine there will be a black variant. Unfortunately I don't know the number.
Its like a dark charcoal colour, very hard to match. Get a sample pot first and make sure you are happy with it. Rub the kit back smooth (ish) high build flexible primer, texture paint, rub back but not too flat, just take the peaks off, colour then drop a couple of light coats of lacquer.
Seems to come out ok.
I recommend Poorboy's Trim Restorer,
http://www.poorboysworld.co.uk/cgi-b...age&db_epid=37
it simply does miracles. I am fixing my very faded plastic elements these days with it.
