Re: Connector guessing game
Cool points still up for grabs folks
Moderator
South East Regional Rep
I think I did a guide somewhere with all loom connections labelled up! Or maybe it was just engine loom.....
First one I think is for the clock?
Second one is after market stereo loom adapter, one is for the speakers and the other for the power supply.
Third picture is for the cigarette lighter.
Fourths connects to the under dash tray that has a rolling dimmer switch so to speak, it adjust the brightness to all the dash lights.
I WIN!....
Thanks very much for the info, however the cig lighter and the clock is already wired up and working
With regards to the stereo photo. The red connector is obv part of the dash loom, but is this not standard? The two black connectors come from the stereo itself.
I do remember seeing an engine loom picture liam. Also came in handy
I'd say you were right with the first being heater controls!
yeah the 4 pin plug goes to the thumb screw and the bulb also goes to the heater control but what the plug I'm holding goes to I'm still not sure
so the 3 pin plug i am holding must be where the fan gets its power from? these 2 plugs and the bulb are on one harness which goes to the heater fan. but can't find any other plug to connect to
i was right enough, it was the fan power feed, took the dash back off to find it was stuck in-between the dash and the fan housing, pulled it back through and ta-da!
1st heater, 2nd stereo iso plugs, 3rd auto box illumination/inhibit not sure, 4th dash lights adjuster.
