car.crash
the airbag ecu is self diagnostic so if you uinplug a airbag the light will appear on the dash. plug the bag back in and the light will dissapear.
the clio 2's suffer from bad connectors under the seats and most have the light on, rejoin the wires proerly and it dissapears withpout needing clip or disconnect the bag and tensioners and fit a 3ohm resistor in their place if going for aftremarket seats and wheel.
if your light wont clear from a disturbance you may have further issues and will need clip or pin out test.
think it get tricky when airbags have fired as the ecu holds the info and needs resetting even if new bags or tensioners have been fitted.
