Hi guys i got myself a 172 flywheel to use on my f7p now i am going to use my 5 box can i use the c1j clutch on the 172 flywheel or i need to buy a 172 clutch kit
c1j is a 200mm clutch
172 fly wheel is 215mm clutch
dont think the c1j cover plate will fit the bigger 172 fly wheel,might have a different pcd also.
note the tdc teeth pattern are not the same as the f7p, so if your running a standard ecu. you may need to alter teeth pattern on 172 flywheel, to match f7p, check all this before you go any further
depending on power output and what the car will be used for, will determin what clutch you will need , if you intend to drag or track , then paddle clutch every time
