Page 2 of 2 FirstFirst 12
Results 51 to 73 of 73
  1. #51
    Apr 2011
    Netherlands
    Re: megasquirt
    Watch my ghetto test-stand :
    Going to look at it tomorrow, hope i'll get some results!
  2. #52
    Non-member SCHWARTZ's Avatar
    Wallington south london
    Re: megasquirt
    quality.
  3. #53
    Apr 2011
    Netherlands
    Re: megasquirt
    Glad i still had some Lego from the old days
  4. #54
    Re: megasquirt
    Great thread this guys
  5. #55
    Re: megasquirt
    Those renault sensors don't produce much output at crank speeds, lots of standalone struggles with them. One trick to test for this is to remove one bolt from the sensor and push the sensor down as close to the flywheel as you can before it scrapes. It makes about 20% more signal at 250rpm crank speed.
  6. #56
    Re: megasquirt
    how fast does that beasty spin at matey?
  7. #57
    Apr 2011
    Netherlands
    Re: megasquirt
    it doesn't spin really fast. i have a replacement trim pot which probably doesn't do what it has to do. unfortunately the electronics dealer doesn't have it in stock so'll have to wait till new year
    also i have a peugeot vr sensor atm and it pushes out a lot more current then the Renault item. 3v vs 1v
  8. #58
    Member Woznaldo's Avatar
    Canberra, Australia
    Re: megasquirt
    Using Scoff's sensor with my EDIS setup and closing the gap from 1.5mm to about 0.9mm ju ped my cranking voltage from 1.2v to 2.5v!
    Nice Lego setup Tutuur! Whatever works...
    Schwartz, great to hear your problems are sorted now! I'm still having issues but think it's Carb related now? I'll pull the carb off and take a look and go from there.
  9. #59
    Apr 2011
    Netherlands
    Re: megasquirt
    Lol, it was what i had at hand first! Now have a v2 with the peugeot crank sensor though. The sensor is strapped down with a zip tie and put some stabilisation lego bars to the triggerwheel fork
  10. #60
    Apr 2011
    Netherlands
    Re: megasquirt
    V2: (3volt with 1mm gap )
  11. #61
    Apr 2011
    Netherlands
    Re: megasquirt
    Finally got the tach input working!
    Op-amp u7 was blown, going to fabricate a bracket for the peugeot vr sensor tomorrow and try to run the 9 on Monday
  12. #62
    Non-member Mart's Avatar
    May 1996
    Pie & mash shop
    Re: megasquirt
    Quote Originally Posted by Tutuur View Post
    PMT at its finest
  13. #63
    Apr 2011
    Netherlands
    Re: megasquirt
    Pmt?
  14. #64
    Re: megasquirt
    Pikey mod tuning
  15. #65
    Apr 2011
    Netherlands
    Re: megasquirt
    Ah, got it!
  16. #66
    Apr 2011
    Netherlands
    Re: megasquirt
    finally have it running
    this is the Peugeot vr sensor with a bracket i made in a hurry (going to make a better one in time):
    the finished product (which probably will be done better too in the future):
    and proof it runs:
    http://www.youtube.com/watch?v=Kno5mGUGRag
  17. #67
    Re: megasquirt
    Sounds ace matey. Seems to rev up really well. Love to see the fuel and spark tables
    Those Renault sensors are poxy.
  18. #68
    Apr 2011
    Netherlands
    Re: megasquirt
    needs a lot of tweeking! this are just maps i got from someone running a f4rt on Megasquirt. haven't got much time yet to do anything with it.
    going away for a while too next week so you would have to be patient
  19. #69
    Re: megasquirt
    Either way sounds like it runs well looks like a really nice project.
  20. #70
    Apr 2011
    Netherlands
    Re: megasquirt
    thanks mate
    how's your car doing?
  21. #71
    Dec 2011
    Re: megasquirt
    Your doing a good job there mate great project
  22. #72
    Re: megasquirt
    Yeah still idled well havnt driven it yet, been making it wider
  23. #73
    Apr 2011
    Netherlands
    Re: megasquirt
    Aha, almost forgot. The 16v track
