Page 3 of 8 FirstFirst 12345678 LastLast
Results 101 to 150 of 354
  1. #101
    Re: my first renault 5 gt turbo project
    Quote Originally Posted by Jonny5 View Post
    That pic is one i have provided for reference to the original post! I may be wrong tho
    might help if i looked at the rest of thread but yeah seen what you mean with the red damper
  2. #102
    Feb 2012
    Nottingham
    You made me think then as I have apex as well an yep they are on upside down.. Just been out to check..
  3. #103
    Non-member Jonny5's Avatar
    Sleaford
    Quote Originally Posted by Nottswoody View Post
    I was the same mate. Luckily i have a few reference pics saved from the rebuild
  4. #104
    Dec 2011
    What a nob i am lol i have just been out and looked one is the right way up and the other upside down it also helps that my mates have just turned up and pissing themselves great lol
  5. #105
    Feb 2012
    Nottingham
    Hey no worries I'm sure we've all done worse.. I reversed while the back was still on the jack.. Thankfully the spare wheel saved it from going through the floor
  6. #106
    Sleaford
    Quote Originally Posted by chris View Post
    Easily done mate, like woody says wouldnt worry
  7. #107
    Dec 2011
    Lol but you didnt put a picture up on the owners club lol oh well
  8. #108
    Motech Tony Walker's Avatar
    Sep 2005
    Parkgate Cheshire
  9. #109
    Sleaford
    He should have done
  10. #110
    Dec 2011
    So got up early today and set about retimeing the distributor up. and then found the fuel pump realay sticking thanks to the advise of the members on here. and it started it will only run on choke at the moment the afr gauge reads 14.9 for 30 seconds and then cant settle then goes up and down like mad. so after i retorque head and do tappets i will try setting it up but as always thanks to everyone who helped. also how do you upload a video?
  11. #111
    Sep 2005
    Parkgate Cheshire
    stick it in a photobucket account with a link
  12. #112
    Dec 2011
    progress has been slow lately but front suspension is on along with braided barke lines so now i have just gota sort running issue's is the idle jet the one thats a big flat screw head ? as always thanks for help
  13. #113
    Sep 2005
    Parkgate Cheshire
  14. #114
    Dec 2011
    thank you mate
  15. #115
    Non-member Benjibrady's Avatar
    Jun 2011
    Bruton
    What a fantastic project, well done
  16. #116
    Dec 2011
    Quote Originally Posted by Benjibrady View Post
    thank you mate
  17. #117
    Dec 2011
    so today bled the brakes again after a bleed nipple snapped in my rear brake caliper and then manged to get the rest of the underneath painted also fitted my new exhaust system so really am getting there now
  18. #118
    Dec 2011
    Also i have got it to tickover but afr readings are15.5 i have searched but cant find what the ideal should be
  19. #119
    Sep 2005
    Parkgate Cheshire
    14.7 is optimum. But if it's leaner and idles fine then that's better. 15 ish is good :-) if it idles fine at that then leave it
  20. #120
    Non-member GTphil's Avatar
    13.9 Will be an mot pass, some camshafts aren't keen on a lean idle
  21. #121
    Dec 2011
    Its got a piper 270 and i havent adjusted anything on carb since rebuild and it was standerd before
  22. #122
    I can't speak from experiance with that camshaft but 14,s should be ok, it's all mostly by ear anyways, as long as it idle's sweet and is above 13.9 your fine
  23. #123
    Dec 2011
    Ok cheers for advise lads
  24. #124
    Dec 2011
    so today after work i went to a stainless steel place and got a piece of pipe so i could exstend my air filter into the postion where the header tank used to be i am pleased with how it looks and i have enough pipe left to make another one if anybody wants it they can have it
    what it looks like off car
  25. #125
    Feb 2012
    Nottingham
    Nice!! hey Chris your not going to leave the expansion tank next to the turbo are you bud? I maybe wrong but that's surely not the best place to have that.. If your going to move the tank you want it all the way over on the passenger side were the frenchies batterie should go.. Correct me if I'm wrong guys??
  26. #126
    Dec 2011
    hi mate it should be fine the turbo heat shield is there i have seen loads with it there and trouble is i dont want to cut bulkhead to run pipes
  27. #127
    Looks good you just need to make a shield for it ajd a nice cold air feed
  28. #128
    Dec 2011
    thanks j tec i thought about makeing a shield but just not that keen on how they look i think it should be ok with just a cold air feed i know it wont be as good
  29. #129
    My header tanks been in that position for years, never had an issue, it was mentioned that the matrix hoses ran close to the turbo but no closer really than the turbo coolant pipes. I have never had a heat Shield either.
    I was thinking about moving it to the scuttle and really simplifying the coolant circut but I just couldn't be arsed, it works fine as it is
  30. #130
    Dec 2011
    Thats ok then i thought i had seen it done before i just cut the original header tank bracket up and put it in place of the airbox holder so i didnt have to drill anymore holes i have spent the last 11 months welding holes up lol
  31. #131
    Feb 2012
    Nottingham
    Quote Originally Posted by GTphil View Post
    In that case I'm moving mine there when the engines out over Xmas .. You see that's what rtoc is all about good ideas and great knowledge and advice.. I don't have a heat shield either I was just worried at how hot it got in there.. What sort of place would I get the stainless from? It's just I would love to re do my pipe work while I have the engine out to get it all done at once..
  32. #132
    Non-member tubbyG's Avatar
    Dec 2010
    what about fitting a turbo blanket/beanie instead of a headshield? I have just fitted one, although not had a proper test, it seems good so far- I can touch it without melting my finger tips
  33. #133
    Dec 2011
    Yea thats a possibilty where did you get yours from tubby g
  34. #134
    Dec 2010
    This is the one I bought
    http://item.mobileweb.ebay.co.uk/vie...d=271042437997
    Bood pointed me towards it...
  35. #135
    Dec 2011
    So done a couple of jobs today, flushed out the cooling system and filled with antifreeze, toped up all the levels again, made a support bracket for the air filter and was going to fit some extra gauges but need some fittings, also touched up some paint work under the archs and my black 90 degree hose turned up so all the pipes are black now. so the engine bay is pretty much finished so thanks to everyone who has helped me with this stage of restoration. i have a bloke comeing tommorow to quote for respray because the original lad let me down but feel as tho the end is in site now.
  36. #136
    Non-member bood's Avatar
    May 2011
    cars coming on great.
    like has been said the turbo jacket is good.
    pm sent
  37. #137
    Dec 2011
    Thank you mate
  38. #138
    Sleaford
    Looking good mate
  39. #139
    Dec 2011
    Cheers jonny got a long way until its near urs
  40. #140
    Coming together nicely mate
    I also had my header tank in the same place for years with no problems, no turbo heatshield either
  41. #141
    Dec 2011
    Thanks brigsy
  42. #142
    Dec 2011
    so tonite i decided to get it out of way and do heater matrix .so i have got it out wasnt too bad as the interior is out of my car, and i have took windsreen out so not to bad, but there was still plenty of swearing i will put it back together tommorow i want to sort some wireing out behind dash
  43. #143
    Non-member BILLY-R5GTT's Avatar
    Aug 2012
    It's coming on now mate, good work
  44. #144
    Non-member gtmatt's Avatar
    manchester,sale
    Top darts mate , what did you ain't arches with
  45. #145
    Dec 2011
    Oh and forgot to say thanks to james 5 who put the link up for a how 2 guide without it i think i would of gone mad because haynes is crap
  46. #146
    Dec 2011
    Quote Originally Posted by gtmatt View Post
    Alrite matt do you mean what did i paint archs with lol if so 2 coats of black hammerite also did all the floor pans and boot floor and bottom arms everything 2 coats lol horrible job and makes me very sad lol
  47. #147
    manchester,sale
    Looks well shiney was it satin one ??? Looks well mate
  48. #148
    Dec 2011
    yea satin mate takes forever but its anything to keep rust away just make sure that you get it clean and dry what you up on urs mate
  49. #149
    manchester,sale
    Thanks Chris
    Just finished my engine , you see my thread ..? Keep up the good work mate
  50. #150
    Dec 2011
    No i aint mate you got a link
