Hello Guys
just thinking to buy jc05 002 gear box from r19 diesel.
Could you give me info about this gear box ?
Thanks
Hello Guys
Thanks
what power you running, as this gearbox will have taller gears compared to megane/williams/172 jc5 boxes, if your running lots of power then it maybe to your likingslower bottom end pick up but good for top end motoring, and steady motorway cruising, just check speedo compatability, or strip gt box and use the speed sensor in the jc5 if needed
Well i'm still waitting for my MS and i need to map it. Will set the boost for 1.5 bar. So no idea what power will have. I'm using b18ft engine with gt gear box. Which is jb3 ...
To be fair HAndy, what did Scoff say, his Jc5 died at 280ft lb but that was down to a large number of hard launches at pod with slicks, launch control, anti lag.
I'd bet a Jc5 would stand up better in a high power road car and I think with the spec isohi-golf put up on a b18ft I think he'll be ok as long as he doesn't drive it like a t**t
