Results 1 to 32 of 32
    Non-member car.crash's Avatar
    Aug 2006
    Renault 5 Gtt H reg
    I may have to sell my white H reg 5. It's a very clean car and it's stripped out and caged up and ready for track or fast road. It's a no expense spared build and the car wants for nothing. It's got a brand new t28 turbo and a hight spec engine with forged pistons, steel liners and a piper 390 cam and will rev to over 8k happily. The spec goes on and on and for anyone who knows the car will know how good it is. It has mint willy wheels with pretty much new Toyos and ds2500 Pads and new 285mm brakes. Fuels lines are all new as are the brake lines. Full ap paddle clutch and a great gearbox. The engine leaks no fluids and runs sweet having only coverd a few thousand miles since the build with receipts to prove. Inside features a freshly powder coated safety devices cage and a pair of new sparco buckets. 6 autogages, 1 afr, 1 rev counter, 1 Ian s temp gauge. I will be sad to see the car go but I'm left with little option at this time. I would like 4 grand for it which is cheap for the spec.
    Non-member Mattw's Avatar
    Jan 2010
    Burghfield common
    Re: Renault 5 Gtt H reg
    Wish I had the cash, great car
    Jun 2010
    Good well looked after 5gtt hope it stays in the club shame to sell
    Aug 2006
    Spec off the top of my head but im sure theres a lot more
    Engine
    Forged pistons, steel liners, bigger inlet valves, 390 cam with uprated valve springs, modified carb, new t28 turbo, forge front mount, huge foam filter, chrome rocker cover, custom rear engine mount, ap paddle clutch, extended clutch arm conversion, ally strut brace.
    Interior
    6 autogauge gauges in a double din console, afr gauge, large rev counter, inlet air temp gauge, short shift gear changer, leather gaitors, sparco rev seats, full satety devices rollcage with harness bar, Luke 3" harnesses, Rear strut brace, black carpet through out with front and rear carbon door cards, 2kg fire extinguisher,
    Exterior
    Polybushed subframe and ARB, Koni adjustable suspension with 50mm springs, Clio Williams wheels in satin black with newish t1r's, new discs all round with ferrodo ds2500 up front and new braided lines and new fuel lines, aftermarket front grill and louvred bonnet, clear repeaters and euro rear lights without reversing light, 2.1/4 ktec exhaust system with a bms large down pipe,
    Bad bits
    Few dinks in the doors and small ones on roof and some rust on the inside of the doors but nothing majour.
    Non-member Andyturbo!'s Avatar
    Oct 2011
    Leeds west yorkshire
    Quote Originally Posted by car.crash View Post
    Engine
    Interior
    Exterior
    Bad bits
    Sounds like a great spec mate, will it come with tax and test aswell? Also does it have much history?.
    Cheers andy
    Aug 2006
    Mot runs out soon so I will get another one done. As for tax I don't know but it's cheap. No real history as I stripped it to a shell a few years ago when I bought it and built it back up using new or very good used parts.
    Oct 2011
    Ok mate. Wot was the shell like wen u stripped it? Did it need any major welding, sills windscreen ect?
    Cheers andy
    Aug 2006
    I welded a few small patches. 1 in the boot and another on the front slam panel. Inner sills are good. I've had no reason to check the outers. Windscreen is good. Best to view it when you have the cash.
    Non-member Coops's Avatar
    lovely looking car, good luck with the sale
    on a tangent, second pic, i spy my motor sticking its nose in behind @ pod ;-)
    Aug 2006
    Open to offers on this. Still got long mot and tax
    Aug 2006
    This car will probably be broken now. If you see anything you want then pm me but im not desperate and won't be giving parts away and it will all be priced fairly.
    Engine is provisionally sold and some parts will remain on the shell ready for its new home but all the bling can go.
    Non-member Biggs's Avatar
    My house
    Charge temp gauge price please mate
    Aug 2006
    £100. Posted
    How much for turbo mate with the oil feed?
    What downpipe did you have on there too?
    Aug 2006
    £380 with actuator and feed. This was a brand new unit from garret and not a refurb one.
    Bms down pipe is on there with lambda boss. £230
    Non-member Romil Davda's Avatar
    Dec 2011
    Short shift gear changer price? I assume this is the actual lever and not the bit that fits into the box?
    Aug 2006
    It is the complete lever yes. I threw away the pin that goes into the box as they are rubbish.
    Jun 2011
    how much for the cage me ol matey?
    Jun 2011
    how much for the cage me ol matey ?
    Aug 2006
    £450 cage
    Aug 2006
    T28, bms down pipe, charge temp gauge sold
    Aug 2006
    Just done a deal pending payment on shell and accessories. Got a few parts left to sell off it in due course but engine sold to a member and shell is going to be a new project for another.
    Mar 2011
    is the cage still for sale?
    Committee member
    Rats Nest Tuning
    Ashy's Avatar
    How much for the Sparco boot box mate delivered.
    Also double din console with gauges?
    Aug 2006
    I only have seats and radiator left guys. The vulchers have cleaned up.
    Jun 2010
    Kent
    What seats are they?
    Dec 2011
    "vulchers" thats the nicest thing anyone said about me...
    Well done with moving everything on, now you just need to get another 5
    Aug 2006
    Sparco rev seats with side mounts on adapted Gtt runners so they are a direct fit. £380
    Kent
    Do they have a date on them? ie 'FIA 2014' or something like that?
    Aug 2006
    They do but off the top of my head I don't know it and I'm pretty sure they are out of date for race use.
    Aug 2006
    Every part sold and shell is gone
