Page 3 of 5 FirstFirst 12345 LastLast
Results 101 to 150 of 207
  1. #101
    Oct 2003
    Re: clio 172 (time for some boost)
    Tomorrow is all set to be the day she's on the rollers, I've returned to work this week so not sure if I can get away to see her pull on the dyno, it'll either be good or bad :-$ if all is good I'll be glad to get her back running with around 240bhp peak. Been looking forward to Friday like a kid does for crimbo. To keep my mind of work I decided to strip my broken gearbox and rebuild it (in my tea breaks) In the car it wouldn't go into reverse so had a look inside, found a bent selector arm so grabbed a replacement for a 5er from agency transmissions in Worcester, checked everything over gave it a clean and now I have a spare working gearbox waiting for when this one ****s a frisbee :-D
    Any one wana guess on what she will put down? Closest gets a curly wurley
  2. #102
    I'll say 246.. good luck
  3. #103
    Non-member TrixNFlix's Avatar
    Preston
    234
  4. #104
    Non-member J8TRO's Avatar
    Stourbridge
    239 Cos it's never quite what you want!
  5. #105
    Non-member Spooky's Avatar
    Sep 2001
    SW PMT HQ
    170bhp/150lfts
  6. #106
    Non-member 5teve L's Avatar
    RH12
    225
  7. #107
    Oct 2004
    Somerset
    172....more if it works..... or you shave your beard..weirdo...
  8. #108
    Oct 2003
    Quote Originally Posted by jesus in the seat of a 5 View Post
    i could shave the beard and gain more bhp to weight straight away
  9. #109
    Oxfordshire
    anyone know the part number for a clio head gasket?
  10. #110
    If it's of any help I use gaskets from these people:
    http://cgi.ebay.co.uk/RENAULT-CLIO-L...item20b42c1359
  11. #111
    Oct 2003
    Thanks for the vote of confidence
  12. #112
    So how did it go??
  13. #113
    Oct 2003
    well good and bad, looks like the previous owner over tightened the spark plugs and threaded the head on number 2, obviously a problem when we pulled the plugs out to find ptfe tape on all of them! even bigger problem when at 5k on the dyno it blows out and takes with it any thread that was left.
    after a long round of phone calls a local engineering shop agreed to lend me the kit to re tap the head and put an insert in there, usually a job done with the head off. as the engine only has to last a few more months until the low comp build is finished i chanced it and did it in situe, i also chanced only fixing the one that flew out completely as the car was strapped to the dyno and we were running out of time to get it mapped.
    anyway she held together long enough to do the majority of the work and i drove her home this eve, theres still alot of work to be done but she is now fully mobile and i can put my foot down, well once i fix the other 3 cylinders.
    i gave her some poke on the way home and it actually scared me, its abit icy out so 1st 2nd and 3rd are useless but the pull on the motorway is awesome, i defo think it needs a longer ratio gearbox as it hits the limiter abit to quickly!
    well on to the figures, these are at .5 bar of boost and ive been told with some more time on the ignition side of things i should see another 10bhp peak (didnt have enough time with the mishap) she made a very healthy 246.5 bhp! not bad going for spare parts and favours
  14. #114
    Sep 2001
    SW PMT HQ
  15. #115
    RH12
    Quote Originally Posted by Adey aka Ewok View Post
    Good going, can you run more boost through it once you have the low comp build in ? Once it's remapped again of course..
  16. #116
    Non-member SP33DY's Avatar
    Mar 2009
    North East
    Good results Adey, how's the boost limited on this set up? a restrictor the same as the others?
  17. #117
    Oct 2003
    Yeah uses a restrictor same as the other setups, more boost will be run with a lower comp engine. I think Rs tuning ran an un restricted setup, made around 320bhp but didn't last long
  18. #118
    Oct 2003
    today she got death, and she still runs
    had the keyed pully fitted up as that has been a common weak point for these supercharger conversions, i have been abit tentative with it up until now but god does she fly, the power delivery is unrelenting, pulls all the way to the rev limiter! will try and up load a power graph of before and after overlaid foir those who are interested, shows the improvements its made as its on the same rollers both times tho i know they cant be all that accurate.
    will try and get a few vids done but if she holds out im sure you will see her at nat day
  19. #119
    Oct 2003
    so shes still alive and still going strong starting to get used to how she drives and to be fair doesnt act feel to fast unless your playing with something else. not too much done to her lately more just racking up the miles.
    been meaning to fit some aerocatches to the bonnet for some time now so that i can loose the slam panel at the front of the car, i had snapped both mounting brackets from the bumper too so added some there too. adding them to the bumper is making things alot easier to access when work is needed so not a bad idea atall, and they removed the screws i had holding the bumper on
    some piccys of how she looks now
  20. #120
    Preston
    Nice work, love the aero catches. Great idea on the bumper.
  21. #121
    Oct 2003
    cheers buddy. oh the other addition i didnt mention was the fog light covers off a 1.2 clio. the drivers one is slotted to allow air through for the oil cooler but thought it tidied up the front a little and gave it that r26r twist
  22. #122
    norwich
    love it
  23. #123
    Really liking the clio's these days. I think I'll be going over to a clio shell next winter.
  24. #124
    Apr 2002
    They've really grown on me. I quite fancy a 172/182
  25. #125
    Oct 2003
    base spec shells and complete cars can be had cheap, you can get ph 1 172s cheaper than 5 gtts nowadays too
  26. #126
    I think it would have to be a white 172 none sunroof for me. No rush though, I'll keep my eyes open for one with a dead engine or whatever.
    Liking the aero catch'd bumper
  27. #127
    Oct 2003
    you going to build it around a base spec shell or respray a 172?
    actually had the idea from the gtt cup cars with the bolts just holding them on, handy with all the pipe work and shiz ive got running around there now
  28. #128
    Stourbridge
    Good work Adey, your Clio looks
    Liking the love for the Clio. Buying my 172 was a great decision.
    Great cars for the money
  29. #129
    Mar 2009
    North East
    Theres a lad on cliosport selling a White ph1 clio shell complete with roll cage. Dannyr is his user name. It's the old RSTuning supercharged Clio. Might be worth a cheeky offer
  30. #130
    Did they not do flat white 172's ? Bummer, I didn't want to have to paint one. I don't want a non-172, I think there would be too much agro in finding the wishbones, suspension bits and whatever else makes a 172 a 172.
    Steve, too soon for me mate, it's something I want to do later in the year else it'll distract me from the R5. R5's getting a bit tired, a bit un-aerodynamic and a bit tight in the engine bay for me these days.
  31. #131
    Oct 2003
    No they didn't make White ones, not in this country anyway. Try and get a silver ph1, they come with Ali bonnets standard, lighter than most of the carbon items available. You thinking of building it for the strip?
  32. #132
    Aug 2004
    White 172s are the nuts....a few out there.... all resprayed that colour tho....
  33. #133
    Non-member Ricardo's Avatar
    Quote Originally Posted by Penfold View Post
    I've been given a price of 1.2k to have mine painted white
  34. #134
    Non-member markey b's Avatar
    Bury St Edmunds
    Quote Originally Posted by SP33DY View Post
    thats my mate who is the local clio breaker, but not by choice! he busts one so keeps it and strips it, and buys another to drive in the meantime, at the mo he has 2x silver ones, and the white one!
  35. #135
    Kent
    I'd quite like a phase 1 172 in silver with no sunroof please.....alloy bonnets???
  36. #136
    Oct 2003
    Quote Originally Posted by Matt@CodeRedMotorsports View Post
    Yep, tho I don't think they are available anymore, insurance companies replace them with steel ones as aparently they can't get them from Renault
  37. #137
    Quote Originally Posted by markey b View Post
    Do you know how much he's asking for the white one Mark?
  38. #138
    Good result then! it's a shame there wasn't a prize I was only 0.5bhp out
  39. #139
    Bury St Edmunds
    Quote Originally Posted by Ricardo View Post
    no but i can find out, any joy with my old raider? i'm like your personal car enquiry manager
  40. #140
    I didn't go for it as too much work for the money, you're my car PA
  41. #141
    Non-member Gttnutter's Avatar
    Oct 2005
    Amersham
    Looks good ads, got me wanting to buy it off you now
    This was my White 172 I had for a year
    Ok so it wasn't a genuine 172 it was a dymanique but had a bare shell spray in glacier White and full 172 engine and running gear. Apart from the roof it wasn't a bad buy and a made some dosh on it when I sold it on
  42. #142
    Non-member TNT Tricky Nicky's Avatar
    norwich
    looks like this now, the new owner works in a bodyshop and had a few bits done and had it blown over inside and out
  43. #143
    Oct 2005
    Amersham
    I prefered the dirty look myself
  44. #144
    Non-member tubby5's Avatar
    york
    that looks very nice
  45. #145
    Non-member Nayls's Avatar
    Weymouth
    Black looks better i think!
  46. #146
    Oct 2003
    I want them wheels!!!
  47. #147
    Non-member raj's Avatar
    Feb 2001
    Rohtang pass
    what are them wheels?
  48. #148
    Weymouth
    look like rota's??
  49. #149
    norwich
    they're 16x8 Rota grid drifts, et 10
    rear arches need flairing due to the et, can get them closer to 35 but they aren't so con-caved
  50. #150
    Oct 2003
    Did a few little tweaks last night, hopefully I can get it on the dyno today or sat to see I there has been much of a change. Still trying to find the time to have the map adjusted also as there are a few points on the map where it needs smoothing out. Also fitted some uprated engine mounts, alot stiffer than stock but the car vibrates a touch now.
    This sat there's a rolling road shootout at powerstation in tewks, if the car lasts long enough she should be there. Open for anyone to spectate and if there's space run
