back again not so much the coilovers now but the adjustable top mounts What ever i do i cant seem to get rid of the negative camber I have the top mounts so the shock nut is as near to the wing as it can get but i still have masses of negative camber. Comparing them to the o/e strut tops it looks like the top of the shock needs to go over even more but cant due to the top mount hitting the rim type thing of the shock tower if that makes sense. on the o/e strut tops the nut goes under this rim thing so do i need to cut my shock tower out??
