Well as usual, what have people got to do in order to be ready for Nat Day this year ??
Me, well the "coupe" is sitting waiting patiently, just need to choose weather to trailer it up or A-frame to Mallory![]()
I need to stop my car from losing water, i don't think i am gonna make it![]()
I might buy another GTT just for ND![]()
Just need to replace rear brake pads other than that I am just fettling for the sake of it now.
I've got my Skyline rear diff, new box (the syncro on 4th has gotten worse since Pod), rear brake lines, rear discs, rear pads, front pads and re-bleed the brake system. Two evenings work on the ramp.
I'll be there & Mich is tagging along too![]()
Im nearly done, just ready to wind up the boost![]()
where do i start![]()
Just new rear tyres for meso lucky.
The gtt only needs a clean & its ready to goNot sure if im bringing the van yet but that only needs a couple of small jobs doing
Find and fit suitable uprated clutch ...fit HKP T04E and 440cc injectors ....test and tune road warrior
take downpipe off, fit boss for wideband sensor and wrap downpipe, refit it, fit wideband wiring and gauge, sort battery box in boot
thats about it i think![]()
Im Done Wahooooooooooooooooooooooooooooooooooooooooooooooo oooooooooooooooooooooooooooooooooooooooooooo
Wait for new Coilovers to arrive (4 weeks) then fit them
Full suspension Geometry Check
Fit Strut Brace (Tomorrow)
Oil & Filter Change
Check brakes & everything else
Then good to go
Oh and fix Millie's gearbox in the mean time!![]()
Side exit and larger intercooler for the trophy
or if i havent sold the R5 then its a big "i did your mum sticker on the bonnet!" just for the cameras.
o and sort the nitrous jets out and fill the tank!
im sorted, the car works, that will do.
just need cash to hopefully get on track, hopeing track time is still avaliable
Coilovers have arrived from TCR racing fit them
fit new hubs and ball joints.
get slicks on rims.
fit de cat.
sort camber.![]()
fit timing chain cover with new seal
service the car
paint the bodykit and grill and refit
put all interior back in
mot the car
paint turbines and fit fresh rubber
its gna be hit and miss if i make it really
I got abit of a list for the campus
-Build engine back up
-Set it up again for new engine spec
-Fit new rear shoes in the drums
-clean the car thoroughly
I'll be racing it week before Nat Day too so if anything goes wrong then it'll be a week off for me to sort it all out.![]()
My list is now getting longer.
So that's now H/G to add to list.
My to do list now
- H/G,
- Turbo replacement,
- Rear brake pads,
- Sort Side exit out,
- Replace coilover springs with stiffer version,
- Front jack points need some welding
- MOT
wonder what else i can break by National Day, might be going in the Zafira GSI at this rate![]()
Well my little car has come on quite nice ready for National day!
Charge cooler fitted. Thanks Turbo Ted & Marc
Ian's gauge fitted. Thanks Turbo Ted & Marc
New oe clocks
Stereo system fitted
cowling made
Things to do are!
figure out the bad charge temp readings
Change carpet
Oil change
Tidy up amp wiring
Fit new pre rad if the right one comes up for sale.
and clean car.![]()
Lower it and maybe fettle with the carb and up the boost
Where do i start?
lol..
here how it looks as of yesterday lol..
Needless to say i need to crack on !
Feckin loads as usual.
I dunno, fix 1 thing, leads onto 3 more needin fixin.
The cars is at it's best/worst it's been.
I need to:
Change clutch AGAIN as the 1 helix made for mr is no good.
Get a leaky chargecooler repaired, then hope charge temps are ok, if not, fit water injection
Change clutch master, possibly for a bigger 1.
Get spare gearbox synchros machined, get all gearbox internals machine polished, rebuild modded gearbox parts into my casings.
Repaint and change drivers rear arch.
Then hope it all holds together.
So not much lol
picked up new laguna gearbox last night, so thats good to go on soon and fixed the split water hose, so all looking good currently!![]()
4 weekends to go people! Chop chop![]()
broked my gear box sad times
Allmost there , myself and matt5 at the weekend put the lsd in the cup,installed a brand new wiring loom too as the wiring was shocking and just waiting to burn..., we cut out all excess wiring and heatshrunk it,put a brand new alternator{genuine} in and new kill switch with diode to protect said alternator..
, also new fire exstinguisher pulley, new light and balance flywheel, loads of other bits too , a bit more attention and were there me thinks....
Jobs Done
- Replaced engine with Rebuilt block,
- Piper 285 cam and vernier fitted,
- Sorted low oil pressure problem with thanks to RTOC,
- Water Pump replaced,
- New Valeo Clutch fitted,
- New H/G fitted,
- Rear brake pads
- Handbrake lever adjusted,
- Replaced coilover springs with stiffer 550lbs version,
- Front jack points welded,
- Removed downpipe to attack the very stiff Lambda Bung
- Renewed connections on sump level indicator and OE oil pressure gauge aswell,
- Turbo replaced with a working unit,
- MOT - Pass no advisories
Jobs left to do for national day
- Set carb up for boost wanting to run using LM-2,
Pretty much ready now for Nat Day, been testing AFR's and looking good as it 12.1 @WOT
Buy a new helmet... thats my job.... ohh dear
I have a spare if you only need for the day MR JRP![]()
No problemo no tongues![]()
Fit cam belt and all ancialliaries - done
Fit new water pump - done
Sort windscreen surround rust - not done
Fit new rear calipers and discs - not done
Fit new radiator - not done
Plumb in oil cooler - not done
Check fueling - done
Paint wheels - not done
Oil and filter change - done
Fit Front wheel bearing - done
Wash and wax - not done
Done
the usual with a proper build...............put fuel in![]()
