If a turbo has in and out play, would i be right in using common sence in saying the blades can come into contact with the housing and thus cause the turbo to stall, if so will this cause the boost pressure on the boot gauge to judder quite a lot, reason saying i have a turbo with a lot of play in it (this will be coming off very shortly once i know my oil pressures are good) , but when boosted on the spot the boost gauge is very erratic., the gauge is measured in psi, and on idle it sits jst below 0psi.
Sorry if the questions is common sence to most of you guys, im new with turbo's so cramming in all the info that i can.
