Results 1 to 19 of 19
    Non-member SP33DY's Avatar
    Mar 2009
    North East
    GT2560r
    Right lads a couple of months ago I had a thread running about the turbo fitted to my clio. there was a lot of speculation and the outcome was that it was a GT2860r.
    Well I spoke to universal turbos last week and the person I spoke to went to the effort of bringing up the info on the computer and its actually a GT2560r with a modified t3 compressor housing.
    The stats are
    Turbine
    -Wheel: 53mm w/ 62 trim
    -Housing: .64 ar
    Compressor
    -Wheel: 60mm w/ 60 trim
    -Housing: .60 ar
    Would anyone like to have an educated guess at the feasibility of running 300bhp+ with it?
    The reason I ask is I'm gearing fuel sytem (pressure/injectors) for 300+ but don't see the point if the turbos only good for 280.
    What effect will the T3 comp cover have over the stock 200sx style comp cover?
    Cheers
    Steve
    Mar 2004
    Salford (manchester)
    Re: GT2560r
    It should be good for 300hp
    Member
    efi-parts.co.uk
    Scoff's Avatar
    Aug 1998
    Liverpool
    Re: GT2560r
    Even at only 300hp it will not be very efficient on that compressor, but it should do it. 300+ is going to be too much to ask though.
    Oxfordshire
    Re: GT2560r
    what engine is this?
    Mar 2009
    North East
    Re: GT2560r
    Well I'm aiming for 300 so that should suffice for the time being.
    The problem is the space between the bulk head and the engine.
    Think if I want a bigger turbo I'll need a nice tubular manifold to bring the turbo round to above the g/box as per Scoffs and Ashy's.
    It's on an F4R Andrew.
    Oxfordshire
    Re: GT2560r
    Quote Originally Posted by SP33DY View Post
    Ok, personally I think that turbo will be too small then, I'll put my money on circa 260hp. For 300 I'd say use a GT28RS with the .86. Not sure if that would fit on your manifold though. Even then, I'm not sure that the log manifold is the way to go for that power.
    http://www.full-race.com/articles/Bs...st_writeup.pdf
    http://www.full-race.com/articles/sr...st_writeup.pdf
    or you could just build it and see what happens
    Member
    efi-parts.co.uk
    Scoff's Avatar
    Aug 1998
    Liverpool
    Re: GT2560r
    Something funny happening at 5000rpm
    Dartford
    Re: GT2560r
    I say it's probably the VTEC cuttin in if it has it???
    Mar 2004
    Re: GT2560r
    4400rpm the GSR lump switchover.
    Member
    efi-parts.co.uk
    Scoff's Avatar
    Aug 1998
    Liverpool
    Re: GT2560r
    Only does it on the one plot
    Dartford
    Re: GT2560r
    O well there goes that theory
    Mar 2009
    North East
    Re: GT2560r
    There is a clio already running 290 bhp and 270 lb/ft running identical set up to me except he's using
    480cc injectors
    255lph fuel pump
    3.5 bar fse fpr
    I'm looking to run it with
    630cc injectors and a 3.8 or 4 bar fpr
    To be honest I think if I spend anymore money on it the GF is gonna execute me.
    It's quite funny, when I set out to turbo my car I only wanted a nice useable/ reliable 220/230bhp. However I've become obsessed with 300bhp for some reason and am determined to get to it. I think it's to justify the amount of cash tht I've thrown at it so far.
    My concern is that once the engine is done I'm going to encounter traction and gearbox issues.
    Only time will tell though, it's booked in for the mapping on the 24th so will post the results afterwards.
    Cheers for all the input
    Steve
    Member
    efi-parts.co.uk
    Scoff's Avatar
    Aug 1998
    Liverpool
    Re: GT2560r
    You won't need that much injector or fuel pressure to make 300hp. 630cc and 3 bar will do you fine.
    Non-member Mart's Avatar
    May 1996
    Pie & mash shop
    Re: GT2560r
    The stats are
    Turbine
    -Housing: .64 ar
    Compressor
    -Housing: .60 ar
    https://www.rtoc.org/boards/showpost....5&postcount=72
    Those 480cc injectors your friend is running should be fine for 300hp, or you could fudge the pressure a bit to be safe. For sure, as Scoff has mentioned, there's defo no need for 630's.
    2560r should scrape 300hp, but at what efficiency? I'd say 28rs, and being slightly lazier/laggy, should retain some form of gearbox reliability.
    Mar 2009
    North East
    Re: GT2560r
    Smart ar$e!
    Best spend some more money and get a 3 bar reg then
    Mar 2009
    North East
    Re: GT2560r
    One 3 bar reg winging it's way to me
    Mar 2004
    Re: GT2560r
    Isnt there an issue to what size you can fit due to not much space? depending on what mani you have of course..
    Mar 2009
    North East
    Re: GT2560r
    Yes Rob it's that tight, that it's had to have special lugs welded to the comp housing to mount the actuator closer to the turbo, otherwise if using a normal actuator bracket it would foul the bulk head.
    If i went to a gt28rs i would need a new tubular manifold
    Non-member MFaulks's Avatar
    Dec 2008
    London UK
    Re: GT2560r
    coming to this a little late, but I'm not really convinced the test is a true comparison. There are too many variables depending on the exhaust port configuration and pressure profile of the flow at the interface that could throw this out (albeit cross cylinder backflow is big disadvantage for the log and example shown is pretty poor for that). I'm sure the tubular manifold has been optimised, and looking at the log probably not. Log manifolds designed with pulse converter branches are especially effective in turbo diesels and don't see why this wouldn't apply to SI engines too.
    ... ummm coffee
