Is there a gasket in the down pipe?
Hi,
Is there a gasket between the elbow and the down pipe? I've tightened mine up as the spring bolts were loose, but it still seams to be leaking.
The garage told me to get a new gasket, but went to car spares today and they showed me that there system showed no gasket in that location.
Is this right, if so how can i stop the leak?
Thanks
Re: Is there a gasket in the down pipe?
Hi, when tighten the spring bolts make sure you tightening each side equally, I know this may seem common sense, but if one side has more tension it will start to leak. Also use a wire brush to clean the two surfaces and then try some paste.
Member
there is a collar(profiled to suit downpipe cup),u should see it in dialogys and its expensive!!...u probably didnt cop it but its there if its an origional pipe.
