Water pump
Headgasket is underway, should i change the water pump?
Heard that if water & oil mix it ruins them.
Honorary Member
Re: Water pump
Just flush the system out thoroughly, so you get all the emulsion out. The pump will be fine. If you like, you can remove the pump and separate the two halves and give it a good clean up to be sure. But it's not really worth the effort unless the cooling system is very clogged with emulsion.
Re: Water pump
I'm probably too much of a perfectionist but I would change the pump if it was all off.
At the end of the day the 5's rely on a good water system for cooling
Member
Re: Water pump
water pumps on 5's usually good for 150k miles,being on top of the engine and only one relatively small belt helps alot!
Re: Water pump
Cheers for that. well its done 90k so i think im going to change it for the sake of £25 and for piece of min. Hopefully i wont have to ever do it again then.
