Results 1 to 17 of 17
    North London
    starter heat shield
    Just wondering if anyone has a starter heat shield on their car ?
    Did they come standard ?
    I ask because I seem to kill alot of starter motors !!
    ta
    Apr 2002
    Re: starter heat shield
    Yes.
    Yes.
    Get one. They're about £20 from Renault iirc.
    Oxfordshire
    do you fit standard, or 'uprated' starters?
    North London
    the last one i got from renault.
    They are all recon starters, they also cost over the odds for what they are thats not surprising from renault.
    Ok I will order from reggie....
    next question..
    What is the part number for the heat sheld ?
    And is there a bracket that holds the above ? (also need part number)
    Thanks guys
    Look-Out Kris M's Avatar
    Apr 2006
    Swindon
    No bracket for the starter shield, its bolts to the back of the block
    Non-member Sy5GTT's Avatar
    Mar 2006
    Deepest Wilts
    Quote Originally Posted by Kris M View Post
    Oh but there is Mr M. It's held on with the starter motor bolts.
    I binned mine off and heat wrapped my down pipe, heat wrap is lighter than metal
    The starter heatshield is only metal on the ph1, the ph2 is the fibre material like the turbo heatshield.
    Apr 2006
    Swindon
    "Oh but there is Mr M. It's held on with the starter motor bolts."
    Oops, forget what i said then
    Non-member Billy-G's Avatar
    Feb 2002
    It changes. A lot.
    Indeed. I'll be putting mine back on tomorrow with the starter.
    Non-member paul-11turbo's Avatar
    merseyside
    starter heatshield - 60 01 009 580 was about £26 last time i checked from renault.
    cgb sells them as well for £29.99
    Trader
    GT Turbo Spares co.uk
    South East Regional Rep
    phase i 16 v turbo's Avatar
    Jan 2001
    Morden
    I have one that I will be bringing to ND as it is no longer need, still in Renault bag.
    Trader
    Jan 2001
    Morden
    Hi just checked with my local dealer.
    From Renault they are :- £29.75 + Vat = £34.96 but will go back order
    From CGB they are :- £29.99 + Vat = £35.24
    From CGB they are :- £29.99 + Vat + delivery = £44.63
    Apr 2006
    Swindon
    PM
    cambs
    do u really need a starter motor heat sheild? guys
    Trader
    Jan 2001
    Morden
    I have had several starters fail on me and when I asked around alot of people told me that is was heat soak, which was cusing them to fail, so I brought one as it is alot cheaper than replacing starter motors.
    Non-member TommyB's Avatar
    Bedford
    I also heat wrapped the down pipe, Had the same starter for 3 years now.
