Results 1 to 9 of 9
    Committee member
    Rats Nest Tuning
    Ashy's Avatar
    Big Brakes?
    Now then, I was having a play around with the brakes on the 5 yesterday. Whilst I had them off I thought I'd have a look at the difference between the R5 discs and the 182 discs I've just skimmed!
    It was quite interesting:
    So the 182 brakes fit spot on, the calipers however are no where near, would need to make a bracket to hold them! Has anyone looked into this or is anyone aware of anyone who produces one?
    I know some people run gtt calipers on bigger discs but it would be nice to run a big set of calipers on big discs!
    Oxfordshire
    Re: Big Brakes?
    can you not just bolt the complete 182 corner on?
    Committee member
    Rats Nest Tuning
    Ashy's Avatar
    Re: Big Brakes?
    The hub is totaly different, I haven't measured it up but looking it looks visably different, can take some pics if you want cos the 182's still in bits!
    Oxfordshire
    Re: Big Brakes?
    pics are always good. I've been on the lathe this morning modifying the hubs so that I can use studs - all part of the Laguna hybrid front end/kangoo rear disk mishmash
    Committee member
    Rats Nest Tuning
    Ashy's Avatar
    Re: Big Brakes?
    Committee member
    Rats Nest Tuning
    Ashy's Avatar
    Re: Big Brakes?
    Its that top arm that bolts onto the strut that looks a lot different to me, its a lot longer and comes off at a different angle!
    Oxfordshire
    Re: Big Brakes?
    gotta be worth a go Does the bottom ball joint still use a pinch bolt?
    whilst you're there, and you measure the diameter of the A/R bar, I never did find out what they are.
    Committee member
    Rats Nest Tuning
    Ashy's Avatar
    Re: Big Brakes?
    ARB = 25mm dia.
    Oxfordshire
    Re: Big Brakes?
    ARB = 25mm dia.
    cool, I best try and find one
