Results 1 to 38 of 38
    Non-member bradzr5's Avatar
    Apr 2009
    North Shields
    ??????? puzzled
    right had a thread up here a while ago TITLE Turbo. basicaly had a split on my oil feed to my turbo changed the part shown below
    started having problems with my turbo as it wasnt boostin to wot is was set at 15psi
    wasnt gettin anythin in 1st got to 10 psi in 2nd 3rd and so on.
    Had one of my mates look at it he said to make sure the banjo connector bolt was lined up correctly as there is a hole goin through it. Done that today and went for a drive to see not the case, if anythin at idle the boost looks better sits were it used too but only gettin 5 psi now. i am gettin more puzzled by this as it looks to me lyk a leak. Wot is the best way to look for a vaccum leak??????
    please can some1 shed some of the vast nowledge on this problem as it is killin me not bein able to drive my beloved car
    thanx
    Non-member IANMM's Avatar
    Sedgley
    Re: ??????? puzzled
    that is the worse picture in the world mate
    Sedgley
    Re: ??????? puzzled
    visually check the pipes for splits you can take them off and blow down them also but you can usually see them....it could be a faulty actuator
    what turbo you got? have you got a after market boost gauge? if so where is it plumed in? and get some better piccys up
    Apr 2009
    North Shields
    Re: ??????? puzzled
    Quote Originally Posted by IANMM View Post
    will get a better pic up lol sorry hahaha, have a t25 and will have to have a look and see were the guage is plumed from.
    I was advised to check the turbo out and see if there was any play in the shaft and there wasnt any at all
    Re: ??????? puzzled
    The banjo bolt/connector doesn't need to be lined up at all, i wouldn't listen to your mates advice...
    The turbo oil feed should go up almost parallel with the block, the o.e feed bolts to the lifting eye on the head. Repositioning that would take the nasty kink out of your oil feed pipe.
    Id be checking for leaks in the boost cct, Oil feed has nothing to do with your boost loss.
    Sedgley
    Re: ??????? puzzled
    check everything is tight...all nuts and bolts on turbo...exhaust...manifold etc
    Apr 2009
    North Shields
    Re: ??????? puzzled
    Id be checking for leaks in the boost cct, Oil feed has nothing to do with your boost loss.[/quote]
    right but could the turbo not be nakered if it had no oil hense the boost loss???? i am new to all this so still learning
    Apr 2009
    North Shields
    Re: ??????? puzzled
    just perchased a load of silicone vacum hose so i can renue everythin and i now there shouldnt be any leaks.
    checked everythin is tight i havent touched any of the boost cct apart from once wen i had to take off my dumpvalve as there was a hole in the vacum hose for it. part from that everythin is as it was before i changed the bolt
    Sedgley
    Re: ??????? puzzled
    well a split in your dump valve would cause boost loss.....take them off and out of the equation while your trying to find your problem....and if your turbo isn't smoking and there is no play in the shaft IMO its seems ok.....it sounds like something simple mate
    Re: ??????? puzzled
    Did you block up the vacuum pipe off the dumpvalve? Check the intercooler/carb top for leaks.
    The turbo will have oil flow regardless where the banjo bolt is positioned, as the oil goes around a channel in the banjo fitting.
    Apr 2009
    North Shields
    Re: ??????? puzzled
    there is a tiny amount of dark smoke wen ya rev but nothin lyk wot i have seen out of these things , the dumpvalve has been removed now had Mr 5 off here come sort it out for me that time.
    yeah it probably is somethin real simple just really wanna find it.
    Apr 2009
    North Shields
    Re: ??????? puzzled
    ahhhh right i see, wot i done to block of the dumpvalve fitted the bung in the intercooler side and on the t-piece i put some cling film over the end rapped it is tape than some more cling film and tape
    Sedgley
    Re: ??????? puzzled
    did you just say cling film...?????
    Re: ??????? puzzled
    That sounds pikey Get a bolt/screw in the pipe & clip it in place, that will most likely sort it.
    Apr 2009
    North Shields
    Re: ??????? puzzled
    yeah why????
    cant breath through it but i had this problem before i blocked it up, there is a screw tie rapped in the end of the tubin the cling film is rapped round that
    Sedgley
    Re: ??????? puzzled
    get a picture up of what you have done mate.....just remember we dont breath out at 15psi do we
    Apr 2009
    North Shields
    Re: ??????? puzzled
    right lol i see
    will go get some pics of the srew and the cling film lol
    Apr 2009
    North Shields
    Re: ??????? puzzled
    the bung and the oil feed pipe is alot better then it was
    the t-piece that my boost guage and dumpvale r fed off, i know it is a bad pic sorry took off the cling film and that is the screw.
    Just noticed this will be gettin replaced tommorrow
    thanx for all this help
    Sedgley
    Re: ??????? puzzled
    bung looks ok.......replace the T Piece setup and the cracked pipe needs changing for sure
    Apr 2009
    North Shields
    Re: ??????? puzzled
    can get t-pieces of ebay will sort that out should have my tubing by tommorrow too hopefully that might be it lol
    Oxfordshire
    Re: ??????? puzzled
    you got a cracking selection of pipes, joints, and plumbing there.
    Non-member TrixNFlix's Avatar
    Preston
    Re: ??????? puzzled
    I'm loving the copper pipe t piece.
    Non-member J8TRO's Avatar
    Stourbridge
    Re: ??????? puzzled
    Next time i have a problem, ill call the plumber......
    Apr 2009
    North Shields
    Re: ??????? puzzled
    hahaha was all on the car wen i bought it lol
    Apr 2009
    North Shields
    Re: ??????? puzzled
    does any1 now the size hose for the rotten pipe i have?????
    Apr 2009
    North Shields
    Re: ??????? puzzled
    changed the weathered pipe gonna take it for a test drive later fingers crossed.
    am i killin the turbo or the engine if i do run it with the same problem but just keep it out of turbo range????
    Non-member UNICRONICUS's Avatar
    Jun 2004
    Isles of Scilly
    Re: ??????? puzzled
    I would replace all vacuum pipes with 4-6mm internal diameter silicone tubing and secure each end to where the connect to with small cable ties. Replace any suspect hose, especially leaky/cracked oil pipes because this will cause problems to the engine/turbo if they break! As has been mentioned already, get rid of the shady t-section, replace with a length of silicon tubing from the carb base to the AEI unit (do the cup mod perhaps?). Check all main boost pipes (from turbo to intercooler, intercooler to carb) for splits, loose jubilee clips etc... Check the carb top for leaks as well, this should be securely fixed to the top of the carb. Check the rod on the actuator to the turbo is still attached as well.
    P.S. Can you take a decent high res pic of your engine bay from a few angles to show the whole setup? Then we can zoom in on things of particular interest.
    Apr 2009
    North Shields
    Re: ??????? puzzled
    Quote Originally Posted by UNICRONICUS View Post
    thanx for the help mate cheers, really is gettin to me now. will change everythin tomoz, and will get some good pics up to so ya can have a look
    could the actuator be fuked??????
    thanx again
    Jun 2004
    Isles of Scilly
    Re: ??????? puzzled
    Quote Originally Posted by bradzr5 View Post
    thanx again
    It's a possibility, maybe the diaphragm is split... Can you pull on the actuator rod with disconnected from the turbo and see if it moves easily or not? This won't tell you if the diaphragm is buggered though but if it's really easy to pull back then maybe it needs adjusting/tightening but be careful with this , only do it up by half a turn and test it out afterwards. Obviously do this after checking and replacing any damaged hoses.
    Apr 2009
    North Shields
    Re: ??????? puzzled
    will have a look wen the weather picks up a little lol
    the pipe that i replaced that leads to a allen key bolt then itleads to the actuator that is why i asked if it could be the actuator but anythin is better then my turbo bein buggered haha.
    got a picture that i will post of my engine bay dunno if it is anny good but if not will take another one wen it stops raining
    Re: ??????? puzzled
    Is your turbo a tomcat t25? Looks like one in the pic. Have you blanked off the original dumpvalve on the comp housing....
    I doubt the diaphragm is split in the actuator, that would make the boost go up not down due to no control.
    Apr 2009
    North Shields
    Re: ??????? puzzled
    i have changed some of the water hoses over but as it stands apart from the new hose i put on yesterday it is the same as the picture above. I know about the plumbing and really want to sort this all out so it looks alot smarter in there
    thanx for looking
    Apr 2009
    North Shields
    Re: ??????? puzzled
    yeah it is a t25, on the comp housing???? will have to have a look
    cant move the actuator rod at all, so the actuator is fine???????
    thanx for all this help lads all a learning curve for me
    Apr 2009
    North Shields
    Re: ??????? puzzled
    sorted now, replaced all the boost pipes and fitted a new dumpvalve and working as normal again thank god haha, now just gotta fit the new front mount intercooler hmmmmmmm how hard is it can any1 shed any light on there own experience's???????
    and just wanna say thank you for all the help i have recieved thanx guys
    Sedgley
    Re: ??????? puzzled
    FMIC are not that bad mate its just your pipe run you have to sort out....search the site there are loads of different options
    Re: ??????? puzzled
    As said previously mounting the fmic is easy it's the pipe run just done one myself but grill mounted instead there is couple a couple of pics on my profile I also had to change the crank pulley and alt belt to campus versions to give some more space.
    Non-member RICHIE's Avatar
    Jan 2004
    BEDFORD
    Re: ??????? puzzled
    there is a bolt missing out your carb top. also how is your breather system plumbed in were does that pipe go to out of the breather pot and goes somewere near the turbo.
    Apr 2009
    North Shields
    Re: ??????? puzzled
    connects with my air filter pipe, i know it needs alot of work but slowly gettin round to sorting it out haha. does any1 now wot i should be doin with all this plumbing????
    does any1 now were i can get a set?????? just ordered some o rings cause mine is a bit worn
