ok so i having a nasty brake problem , please bear with me this is going to be long !! Every morning get in car and the pedal is almost not exsistant but after 5 10 mins (5 miles) the pedal is fine ! However after another 10 mins the brakes junder on there own accord and you can feel it through the steering wheel ! ok still with me ... good ! On the way home the brakes done the same thing but it takes half the time , finally when ever i reverse day or nite the rear brakes bind on and make a high pitched squeel ! The car has been lowered and has braided brake hoses and red dot discs and pads if that makes any difference ! So what is causing this as its costing me loads of fuel ! Thanks in advance
