Over the last couple of days I've changed my radiator, everything is plumbed in, no leaks, 'no air' in the system...
Anyhow...
Before I changed the radiator, the fan and the cooling system itself was spot on until yesterday.
I fired the car up, let it get warm/hot, the needle approached the half way to 2/3 mark where I would usually expect the fan to cut in but it didn't. I let it cool down, rebled it again and ran the car upto temp until the fan came in...but it didn't.
I have missed the temp switch out by bridging the connection and the fan still won't come on. I have checked the switch coupler with the car ignition on/mulitmeter and found NO power at the switch. Having seen that, I tried another relay and still the same effect.
Now, I'm not getting power to the switch hence me thinking I have a broken circuit somewhere around there. To see if the fan itself is duff or not, can I stab with a live direct from the battery ?
What is the best way to go from here ?
