wideband
weres the best/cheapest place to buy a wideband gauge from i wont a good one mind stack/spa something like that cheers
Re: wideband
Graham Goode Racing, Innovate LM-1 or LC-1, and mention you're from RTOC.
Alternatively, go direct to the manufacturer: http://www.innovatemotorsports.com
The Zeitronix units are also good, as are the Stack items.
Fwiw, imho, LM-1 is king though.
Re: wideband
Edit: Innovate have also recently released the LM-2, which looks the don.
Honorary Member
Re: wideband
Because the prices are similar between the LM-1 and the zeitronix, i would go with the zeitronix. It has much more features that are already built into the kit, for a start you can log rpm right away without having to pay extra for it, like you do with the lm-1.
But the biggest benefit is the sample rate on zeitronix, it is far superior than the LM-1.
My only advice is go for the round display as it show up better in sunlight.
Maybe i am biased as i have the zeitronix
http://www.zeitronix.com/
Re: wideband
Is this a good investment to get, even if you know that your fueling is set up correctly? As in can fueling go wrong after a while?
