I'm just after a general setting for the flywheel bolts as I gave my Haynes manual away when I sold my last 5.
And, if someone has the crank pulley one too, I suppose you could let me know, otherwise i'll just nip it up.
45n for the flywheel bolts .Crank nut 180n but then I have a proper MANS engine
flywheel bolts for the 5 are 50Nm off the top of my head. must use thread lock though!
Clee, when your MANS engine starts punching its weight the lowly C1J will rise to the challenge
There's style and grace to factor in as well ...it's not all about POWER
But .....How about we organise another THOR RR day for end April/beginning May ???
I need some figures
the GTA is a lovely car...although to be honest i still prefer the A310. -Pass me my medallion!
a RR day is definately needed, but what is the turn out likely to be?
there was one at Weston Performance a few years ago that went well.
But obviously the Thor ones are the ones to go for!
Wackachow !!!Flock me !
We should arrange it as Ashy did for the Northallerton bash That filled up and it was the middle of Winter .
Put virtual deposit tickets in the shop, then when we have enough confirm the day with THOR ??
sounds like a plan MAN
I've done the flywheel bolts up to 50nm, so if they come undone, i've got your turbo, Mark
did i mention i usually do em up abit more?
i've had a flywheel come loose before after doing them up ratchet tight lol... wasn't fun taking the box off just to fix a schoolboy error!
all important bolts get my impact gun treatment now lol
Well, the car's back up and running with my new funky elbow and downpipe. The flywheel didn't fall off on the test run, but I did run out of fuel.
I don't intend on blowing things up, it just happens...
It'll be on a trailer at Pod in May, then some track days I guess. I'm hoping my bad car karma goes on holiday for a while.
Bad car karma, well just make sure there is oil in the gear box ehh... if it blows at pod ile buy it off you, i fancy that raider... that and one other are the only 2 id ever wanna own, MARKS SELL UP TO MEEEEEE MEEEE I TELLL YOU...
Lets hope that old trustys spirit has magicly jumped into ur 5
I actually thought about selling it earlier, just as I got it running. It's probably exactly how Mart used have it now with the full cage in it along with a couple of other bits. It's nice to drive though, it gets a bit lively on boost. I kept popping the carb top off but that seems to be sorted now.
Don't you dare sell it, you've spent so much money/time getting it back to it's former self. Now it's time to finally enjoy it
I tell ya what, Mart, i'll even let you have a spin in it if you're at the Pod day. I've only got to fit the charge cooler, as it's using an aly replacment intercooler at the moment to get it running and take it out on the road.
Also, I thought you'd given up waiting for the first refusal and bought Phil's motor to cradle
Jon, i'll think about it
It's not that interesting, but I was quite chuffed with my elbow, when I got it in the mail today
And I had the ring gear changed on the flywheel, so I didn't have to get another one machined
Those pictures make me want another 5
Those pictures make me happy I havnt got a car I need to get filthy with
