Results 1 to 8 of 8
    Part Number required - Oil return to sump Hose
    Morning,
    I am in need of yet another part number this time it is to stop an oil leak. The part I need is the Rubber oil return pipe that joins the phase 1 sump to the metal pipe (Looks like the connection on there at the mo is a bit to big and someone has pushed a piece of silicone tubing on to fill the gap)..
    Many thanks James
    Non-member 5teve L's Avatar
    RH12
    Re: Part Number required - Oil return to sump Hose
    Morning,
    Many thanks James
    Shame it's ph 1 you want James as i have a ph2 ... Measure & get a 90 from SFS or Samco, look on rally design site & get flourolined.....
    Think mine is dare I say it an MSM bodge job
    I used a samco reducer 90 deg hose from rally design, cheap as chips. Think it was 16mm i.d - 20mm i.d reducer, not 100% though.
    RH12
    See James, it's not hard
    I am just lazy
    Non-member Spooky's Avatar
    Sep 2001
    SW PMT HQ
    https://www.rtoc.org/boards/member.php?u=135
    yer man for part numbers
    Trader paul b's Avatar
    Jul 2002
    PHS 1....
    90 DEGREE OFF SUMP 6001007441
    TURBO EXIT 6001007440
    PHS 2
    90 DEGREE OFF SUMP 6001022204
    TURBO EXIT 6001022208
    The phase 2 numbers used to be mixed up (in error) on the system...I do not know if this has ever been sorted so the ophase 2 numbers MAYBE the wrong way round
