Results 1 to 32 of 32
    Non-member Freeman13's Avatar
    Feb 2009
    Nantwich (Cheshire)
    Engine under compression!!?
    Hey guys well what i thought was oil coming out of my dump valve is actually oil being pushed up out of the dipstick tube, im guessing it must be a piston ring causing the engine to put the bottom end under compression??
    Has anyone else had this sort of problem?? have gone over my breather system and is all fine, oil has been drained and changed.
    any help would be much appreciated
    cheers chris
    Non-member RICHIE's Avatar
    Jan 2004
    BEDFORD
    Re: Engine under compression!!?
    Quote Originally Posted by Freeman13 View Post
    cheers chris
    have you tried a compression test. does the car breath heavy out of the oil filler cap. is the car smoking at all. the symptoms you are describing do sound like a possible ring failure mate
    Feb 2009
    Nantwich (Cheshire)
    havent done a compression test yet all my tools are still down south need to pick them up soon, i shall try and get a tester from halfords in abit.
    There is abit of smoke out the exhaust not much but it does breath heavy out the oil filler cap, if it is the rings how much am i looking for new liners and pistons with rings??
    Non-member raj's Avatar
    Feb 2001
    Rohtang pass
    if its the rings, why not just give the existing liners a quick rehone and replace the rings? job done i would have thought a set of rings are around £60.
    Dec 2004
    Aylesbury
    Sounds like pistons rings are worn out and presurizing the bottom end, pull it apart and see the condition of the liners they may be ok and just need a clean up with a new set of rings on the pistons.
    If not a full set of new pistons/liners will be about £160-£180
    Feb 2009
    Nantwich (Cheshire)
    how hard is it to rehone the existing liners?? How hard of a job is it to remove the pistons on the 5??
    Dec 2004
    Aylesbury
    Not hard at all mate to hone liners, to remove the liners and pistons you need to remove the head and sump, undo the con-rod bolts and then pull the liner/piston out from the top. Could have it stripped down in about an hour or so if your confident to do it.
    Feb 2009
    Nantwich (Cheshire)
    yeah should be ok doing that, well i know what im doing tonight then lol
    Mar 2004
    Salford (manchester)
    Dont forget to add gasket sets in your price as you will need both base and top sets... GSF best place for these and dont cost more than £50-£60 for the pair..
    Feb 2009
    Nantwich (Cheshire)
    is there anyfin else i will need?? is it worth going uprated head gasket??
    Mar 2004
    The set from GSF is the uprated headgasket.. Its just thicker than the std gasket, so not uprated in anyway in its structure from what i beleave.. either will do fine tho.. Dont forget price up oils and fitlers and coolant ... All adds up so its not the straight forward £160 for the piston/liner kit
    Oxfordshire
    of course, you might just need to fit the dipstick in a bit tighter...
    Feb 2009
    Nantwich (Cheshire)
    lol im sure the dipstick shouldnt pop and and oil spray out unless thats what all 5`s do??
    Oxfordshire
    Non-member DaveMayGTT's Avatar
    Fareham
    Im sure ive seen other people post similar probs with dip stick and its just where the tube it fits in need crimping as its become loose with age. Not saying you dont have other probs obviously but worth a try
    Feb 2009
    Nantwich (Cheshire)
    yeah will give it a try, will compression check it 2moro and go from there. will let you guys no the results what sort of compression am i looking for??
    Dublin/Ireland
    9-10.5 bar,check manifold one way valves and breather pipe restrictor for blockage!!
    I certainly wouldn't rule out what Andy's mentioned - I've had to crimp the end of the dipstick tube (ooohheeeer!) myself due to the same problem
    Non-member Adam 005's Avatar
    Dorset
    my gt used tp blow the dip stick out.Cause the plastic goes hard on the stick over time i put a little bit of tape round it problem sorted.
    I have aso seen the hook bit get caught on ht leads and dislodge this way.
    Honorary Member RichR's Avatar
    York/Selby
    I believe there are two designs of dipstick for the GT Turbo- the earlier one tends to blow out once there's any level of crank case pressurisation (which with the simple breather system can happen) - and the later type that stays in better.
    But you really should see if the dipstick blowing out is a result of worn rings, and a compression (or ideally a leak down) test will give you a good idea.
    Feb 2001
    Rohtang pass
    are new dipsticks still available..?
    Nov 2008
    You cant beat a bit of dipstick crimping.... and its nearly weekend too!
    Mine blew oil everywhere..it was so bad I had it towed home as a precaustion and no my rings wern't foooked.
    Dorset
    look under members
    Feb 2009
    Nantwich (Cheshire)
    Right well i havent had time to get a compression tester yet, but i put some tape round the dipstick to hold it in and started her up after running on idle for about 3 minutes it was pushing oil out of the rocker seal as it was pressurizing the top end
    Oxfordshire
    that's not a good sign
    Non-member Adam L's Avatar
    Feb 2003
    SW London
    I did that on my first Pulsar engine, although I was at about 7k rpm in 4th. I covered the dual carriagway in oily smoke...
    Needless to say, i'd mullered a piston.
    Feb 2009
    Nantwich (Cheshire)
    Thats not the kind of thing i wanted to hear lol
    Mar 2004
    Sounds like you need an engine rebuilder Still go ahead anyway with compression test and do the old oil down plug hole test..
    Feb 2009
    Nantwich (Cheshire)
    is that an offer lol??
    Mar 2004
    Drop me a pm..
    Feb 2009
    Nantwich (Cheshire)
    Ok finally got some time on the 5 rebuilt my carb today and got round to do a compression test these are my findings.
    cylinder 1: 10 bar
    cylinder 2: 10 bar
    cylinder 3: 5 bar
    cylinder 4: 10 bar
    Tipton
    ringa dinga ding!
