Results 1 to 27 of 27
    Non-member Hez's Avatar
    Mar 2009
    North East
    Starting / choke problem..?
    The 5 has been sat in a garage for a couple of years, i changed the oil, put fresh petrol in and checked everything over at the wekend.
    Had a few problems
    - Had to bump it off to get it running as it wouldnt fire up (was a new battery fitted)
    - Will only run with the choke on (even after its warm)
    Took it down the lane a couple of times, checked it over for leaks or any visual damage turned it off.
    Next morning it wouldnt start again, obv the carb will need a clean but is there anything else anyone can think off
    cheers!
    Qick pic of the bay
    Non-member RICHIE's Avatar
    Jan 2004
    BEDFORD
    Re: Starting / choke problem..?
    is the mixture screw still in situ mate. clean the carb out and see if your idle is set try turning it up a little
    Loose Bolts Tuning stuTHC's Avatar
    Dec 2005
    Leeds
    If it's been sat few a few years clean/replace the plugs, check all the ht leads at the connections for any corrosion, make sure the coolant system is bled and topped up and it might be worth giving the brakes and lines a once over.
    Non-member gtmatt's Avatar
    manchester,sale
    dizzy cap also , condention can form inside the cap , worth replacing the cap and arm
    Mar 2009
    North East
    Think its about due a service, il get K-Tec rang up tomorrow and order a few bits
    Just put new 285mm Willwoods on not so long ago
    Is there anywhere up in the north that you would recommend to set up my boost controller when it running?
    Jan 2004
    BEDFORD
    Quote Originally Posted by Hez View Post
    the rtoc shop sell carb refurb kits
    Mar 2009
    North East
    Lol u on comission i heard
    manchester,sale
    if you need service bits get them from gsf a little cheaper then ktec
    Mar 2009
    North East
    Cheers mate, link? number?
    Jan 2004
    BEDFORD
    http://www.gsfcarparts.com/
    Mar 2009
    North East
    Cheers!
    Committee member
    Rats Nest Tuning
    Ashy's Avatar
    Hi m8, where abouts are you in the NE?
    Mar 2009
    North East
    Just out side of middlesbough mate.
    Non-member scratcher's Avatar
    Milton Keynes - ish
    I purchased a carb refurb kit from the shop today, t'was a bargain!
    Nov 2008
    Hi Hez.
    Welcome to the club mate.
    Mine had been stood for a couple of years. ( errr 9 in dry storage) before I got my hands on it.
    The rear brakes suffered the most. Calipers and cables seized. Make sure everything is A1 and freed off. I put new calipers and cables on mine as they were beyond salvage.
    Thorough carb clean and mixure/idle screw set-up will probably sort your idle probs.
    Mar 2009
    North East
    Cheers guys!
    Il buy the carb clean kit and see how that works
    Mar 2009
    North East
    Update -
    Manage to refurb the carb and she started straight up, only to cut out 20minutes later.
    Took the carb to bits again checked everything but still no joy. took the fuel pump off and tested it on a battery, but it just kept jamming so tried the terminals the other way and she worked. tried them back the right way and she was pumping!!
    Put the pump back on changed the filter and she's been right ever since
    Cheers for all your help and advice guys!
    M.O.T tomorrow!
    Good work mate, if you get stuck give me a shout, only down the road. Did you used to own a 106 gti...
    Mar 2009
    North East
    Cheers mate, yer i still own it av seen your white one a while ago. do you still have it?
    You couldnt recomend anyone to set-up my boost controller and carb?
    Bogg brothers?
    My white gtt is in a million bits mate, started restoring it but got distracted with the van
    Bogg brothers are supposed to be ok, Never used them myself though. Buy yourself a wideband afr gauge & have a crack at setting it up
    Aug 2004
    A good thing to do is to fill up with some decent fuel as the old fuel may not be at its greatest and you will want to flush it all out.
    Mar 2009
    North East
    Brigsy - ive seen the van..thats quality!
    Passed MOT yesterday then spent 4 hours driving about lol seems to be running better everytime
    Mar 2009
    North East
    Set up the boost controller lastnight ready for a rolling road set-up on saturday
    Jan 2004
    BEDFORD
    Quote Originally Posted by hez View Post
    set Up The Boost Controller Lastnight Ready For A Rolling Road Set-up On Saturday
    R11102
    Apr 2009
    sevenoaks
    i have the same prob, when u say refurb the carb did you clean it out or replace the seals and gaskets? if its a caser of cleaning out thats easy, i have to have half choke and pump the throttle like mad till it starts, usserly like 6-10 seconds
    Jan 2004
    BEDFORD
    Quote Originally Posted by R5GTTRaider View Post
    thats normal thats why the put the perc fan in situ to try and stop the fuel evapourating within the carb.
    Apr 2009
    sevenoaks
    so whats the best way to start one ? my perc fan dosnt work so removed it. any way of having a electric pump on ignition? or is that not work till the engine is cranking?
    edit:
    posted a qestion to the wiz and he says ,
    "Wizard replies:
    try cleaning out the accelerator pump jet. its the little bent brass thing that squirts fuel down the venturi. or makin sure the accelerator pump itself is crud free."
    would this solve my problem? im not qestioning him im just wondering if taking the top of to reval the bowl and make sure the jets are clean and this brass tube etc. and proceed to fitting the nw fuel filter i keep meaning to put on! would this make much diffrence or am i wasting time and maybe disturbing a otherwise working carb?
