Ok here is another idea in search for more power and reliability.
Std. E7J engine is a 1390cc (75.8x77) with 9.5:1 c/r SOHC engine.
The possible advantages I have in mind are:
1-no pushrods so should be able to handle some revs without any major problems
2-hemi head
3- Larger inlet and exhaust valves as std.
Inlet: 37.5mm C1J inlet: 34.2mm
Exhaust: 33.5mm C1J exhaust: 29mm
In addition to the basics of this engine I was thinking, we could use the 84mm crank and 76.5mm dished pistons from C2L engine (available for a very reasonable price from Turkey).
The only downside I can think of is the high c/r for forced induction, but we really need to find out the combustion chamber volume to be able come up with predictions as to what can be done to lower the c/r.
And there’s also the hassle/cost of custom inlet/exhaust manifolds. Bear in mind that the exhaust manifold is at the front of the engine. Inlet manifold will only need to be custom made if going the EFI route or it can be adapted to take the 32DIS.
I came out with a rough figure of 34cc for combustion chamber volume which is pretty small compared to Gtt head. I also guestimated the dished area of C2L pistons (I will have to dig out my pistons and take some proper measurements) and worked it out to be 8.3:1c/r with a 2.2mm gasket squashed to 2mm(if it can be sourced) and machining the combustion chamber volume to 38cc (assuming there’s enough meat in the chamber).
So what do you think people shall I prepare to get my life jacket on once more
