Page 1 of 2 12 LastLast
Results 1 to 50 of 95
    Non-member RICHIE's Avatar
    Jan 2004
    BEDFORD
    my efi converison
    just thought i would post up some pictures of the efi conversion im doing using michael tierneys manifold. i havnt got a pic of it including the fuel rail yet as it still wet from being painted. i have some bosch 803 injectors to go in and have sourced all the other relevant parts from scoff ie trigger wheel crank sensor water temp sensor coil pack and ecu all available from http://www.efi-parts.co.uk/Products_1.html
    my tubular manifold needs modifying slightly as the last run on it doesnt clear the inlet so just needs tweeking slightly.
    will update with pics when the top end is completed with fuel rail injectors ect.
    https://www.rtoc.org/boards/album.php...pictureid=5125
    https://www.rtoc.org/boards/album.php...pictureid=5124
    Oct 2003
    Re: my efi converison
    is that one of mikes inlet adapters?
    Mar 2004
    Salford (manchester)
    Coming on well Richi... what size body you using?, i guess with the extension of manifold runners you can run a single fuel rail rather than two looped should look good.... still got all my clobber for an EFI coni sat on bench... May well carry it on one day but other projects come first at mo....
    Jan 2004
    BEDFORD
    Non-member Schakal's Avatar
    Barry
    that looks awesome mate ,fair play to you
    what sort of power are you hoping to achieve in the end ?
    Non-member tubby5's Avatar
    york
    what fuel rail are you using???
    Mar 2009
    Milton Keynes
    looking tidy man thats gonna be a fine bit of engineering when its all together
    Jan 2004
    BEDFORD
    michael tirney built the manifold up and made it so as for the parts hes used you will have to speak to him. as for how much power tbh ive not set a figure im not to interested in massive power just want some reliability and fun.
    Jan 2004
    BEDFORD
    https://www.rtoc.org/boards/album.php...pictureid=5477
    https://www.rtoc.org/boards/album.php...pictureid=5478
    just a quick update on some pics that people requested regarding the angle of the injectors hopefull they give you a good indication. just need to make a bracket to hold the fuel rail in situ. will update in the week with more pics of coil pack and trigger wheel ect in situ
    Jan 2004
    BEDFORD
    picture update of the trigger wheel and sensor bolted on to the crank. the pulley wheel sits behind the trigger wheel and the clearance between the wheel and sensor is 1-2mm.
    https://www.rtoc.org/boards/album.php...pictureid=5656
    Mar 2004
    Is that one of scoffs brackets? think i mite change my homemade one for this, looks tidy.....
    Jan 2004
    BEDFORD
    yes it is mate its a very good fit and was convienient at that price i also got one of the coil packs he sells with ignitors but not to sure were to mount it just yet as i need to see what room i will have when the engine is in. might get some leads made up so i can move it onto the side of the block out the way of the rad and cooler.
    Kent
    Do you have to take the VR sensor off to muck about with/change the auxilliary belt?
    Jan 2004
    BEDFORD
    Quote Originally Posted by Matt5 View Post
    no the trigger wheel is only slightly bigger 10mm approx than the bottom pulley and does not interfere with fitting/removing the belt. the sensor shouldnt need to be touched.
    Non-member scratcher's Avatar
    Milton Keynes - ish
    I'm well impressed with the work going into this mate.
    The bracket for the sensor looks like it was there from the factory, top stuff
    The wheels pretty sharp too, haha.
    Non-member Ron's Avatar
    Leicester
    Is the sensor from a Fiesta as it looks the same as the one i use with my megajolt?
    Jan 2004
    BEDFORD
    Quote Originally Posted by Ron View Post
    i would say its a fair chance its used on many cars i got it off scoffs efi site mate.
    Jan 2004
    BEDFORD
    well after having the day off i decided to get my manifold modded to allow the inlet to fit. pretty happy with it at the moment still abit to do but at least its getting there.
    Non-member TrixNFlix's Avatar
    Preston
    Good stuff. When do you hope to be up and running for richie
    Jan 2004
    BEDFORD
    well the head is all bolted up to the block now and all seems a good fit. all thats needed to do is paint the gearbox and fit the clutch then drop it in for the wiring of the ecu and plumbing up.
    Jan 2004
    BEDFORD
    all depends on how much time i get mate just remembered im to order two new driveshafts i forgot there essential for it to move. the ecu will come with a basic map on it from scoff and he is also making me a loom up to make life a little easier. need to remove the old fuel tank as i have the alloy one going in the boot and need to source a new fuel pump. but pretty much there.
    Preston
    Fingers crossed for you Richie. I know that feeling though, their aren't enough hours in a day!
    Jan 2004
    BEDFORD
    fuel tank now removed and new tank in situ just needs to be secured i didnt realise how much they actually do weigh and how much space it has created under the car now. have also decided to underseal it so thats a job for tommorow.
    only thing im not sure on is the capacity of my new tank at 5 litres i got a feeling im going to be forever filling it up.
    Oxfordshire
    5L LOL, my hillclimb tank is 6L
    3mins running FTW
    Jan 2004
    BEDFORD
    3mins running FTW
    if you were to drive normally how many miles will you get out of that mate. the weight i just lost may be gained with the amount of jerry cans i will have to carry
    Jan 2004
    BEDFORD
    picture of the tank in situ im only guessing its roughly 5 litres. i will probably end up doing a matt not normal and break down on the first lap.
    Oxfordshire
    30 miles maybe...
    your tank looks bigger than 5L, what are the dimensions?
    having the filler neck inside the car ensures the insides always stink of fuel, plus it's a right arse filling it up.
    Jan 2004
    BEDFORD
    30 miles maybe...
    i will measure it up tommorrow it looks bigger in the pic tbh. what was the arithmatic for working out volume again
    Oxfordshire
    1L = 1000cc = 10cm x 10cm x10cm
    so if your tank is 20cm x 20cm x20cm = 20x20x20 = 8000cc = 8L
    Jan 2004
    BEDFORD
    thankyou andrew
    Jan 2004
    BEDFORD
    its 2 gallons so near 9 litres still not many miles though
    Jan 2004
    BEDFORD
    just got back in from outside undersealed the underneath of the car and looks spot on.
    Jan 2004
    BEDFORD
    well thanks to markymark and rich aka gt nutter we dropped the block and box in last night and today i spent a few mins fitting the head up ect . got to make a cross member to allow my intercooler to fit then i will get the rest plumbed in then im going to have a go at wiring up the ecu.
    Jan 2004
    BEDFORD
    a pic would help
    Preston
    Looking great Richie. Is this gonna be an everyday car, or just weekends and track?
    Preston
    Sorry just remembered size of fuel tank.
    track it is!
    Jan 2004
    BEDFORD
    hoping weekends as well as track days.
    Preston
    What turbo are you planning , some sort of t25 so it's not to laggy on track?
    Non-member FurioKid's Avatar
    Lincolnshire
    that looks well tidy mate, would love to put EFI on mine but wouldn't really know where to begin and how much it would be to do the work??
    Jan 2004
    BEDFORD
    Quote Originally Posted by FurioKid View Post
    beginning it is the easy part its finishing it thats the tricky part me thinks.
  41. #41
    Lincolnshire
    yeah i know what you mean so as to make it look nice and tidy, but to be honest you've done a great job
  42. #42
    Jan 2004
    BEDFORD
    A little more progress due to time ect but it a update never the less
  43. #43
    Non-member modfather's Avatar
    thats a very nice bay chap
  44. #44
    Oxfordshire
    are they bluetooth spark plugs?
    looking good
  45. #45
    Non-member Mudslinger's Avatar
    Feb 2003
    looks nice m8
    have you removed the dizzy completely ?
  46. #46
    Jan 2004
    BEDFORD
    Quote Originally Posted by Mudslinger View Post
    looks nice m8
    im yet to make something to fill the dizzy gear drive i know i need most of it to drive the oil pump but i was hoping to fabricate something to finish flush with the top of the block. im sure sure were im fitting the coil pack yet so was going to get some leads made up to the exact length just to look tidy.
  47. #47
    Non-member Nayls's Avatar
    Weymouth
  48. #48
    Feb 2003
    i was planning to get something cnc machined ,to use as a cap ,ive just never got round to it
  49. #49
    Jan 2004
    BEDFORD
    ive not looked into it yet maybe we will have to get our heads together to knock something up. it cant be that hard
  50. #50
    I ain't got anywhere with it either myself, all I did was cop the pin the rotor arm slides over off and make up a flate plate of ally and screwed it down
