Clio 1.8 16Valve Rear Axle problem
Hey guys!
Im in a bit of a sticky situation
Went at dropping the rear axle on my Valver last night, said id get cracking at it so took off the plastic cover at the end of the torsion bar only to notice a sheared bolt in there - it sheared right to the end. My question for you guy's is do I go somewhere to get the bolt removed(Iv tried getting it out myself but it seems pretty daaaaamn stuck in there) Or...... or or or; Can the Arms of the axles be removed(Ive the axle now off the car) With a pullers preferably?! The better option is to get the bolt removed im thinking myself?
Re: Clio 1.8 16Valve Rear Axle problem
Got it sorted, She's an open torsion so I just took the other side out first & took the torsion with the bolt threaded in it out from inside, Sound anyway.
