grabbed a bosch o/e effort off clee, cheers mate
quick question, can i just stick it on and use it to atmosphere, will it be damaged by that? or does it have to be fully plumbed in to work?
cheers
cheers
It will be fine .
Poor mans Dump valve innit ..Sick a party blowout on the end
Depends, are you running a MAF? Some MAF cars wont have any of it, it'll idle and run like poop.
nah, thank god am map all the way, only way you can stick a turbo on the clio lump in the first place easily, lol
i'll stick it on for the crack then till i sort the pipework
Oh course, you can run the 12t MAP sensor cant you. Yeah, should be absolutely fine in that case.
