Carbon fibre doorcards
Im thinking about getting some carbon doorcards, was just wondering if anyone had a any pictures of theres also thinking of how to go about the door handle latch would be good to see others.cheers
Re: Carbon fibre doorcards
You can use the standard handles. Swap the sides over and mount the horizontally.
orite thats good do they sit flush when doing that? Also I would properly get them from www.performance-trim.com has anyone had got them from there and had the handles cut out by them if so do you know the measurements you gave them
as above you can use the handle just turn it, this is the only picture i can find of mine... iv tidyed them up now.. trial fit
use mk1 clio handles as they sit nice and flush, you just need to bend the metal rod coming off the original handle by 90 degrees. i also cut the holes for the handle myself as performance trim said they cant offer them pre cut due to the way the original handle sits.
Great job with GTT handles fitted
they never fit the width of the door on the bought ones...
