Results 1 to 9 of 9
    Jan 2017
    car re-trim price
    Hello all, im just checking if the prices i have been quoted seem right for a full retrim on my seats. I would be providing all material and i have still been quoted between £1000 and £1500. I thought this was really steep consdidering I can get a full suite out of Dfs for less Any help or advice would be great cheers.
    Re: car re-trim price
    Yeah that's not right. I would certainly shop around and get a few quotes.
    Moderator
    South East Regional Rep
    LiamR's Avatar
    Dec 1998
    Medway, kent
    The best price I have had is £1k. So your not a million miles away from that.
    Jun 2010
    whoever you use, first ask to see examples of their work, i have seen some fantastic re-trims and some right bodge jobs.
    1K should buy you a reasonable quality re-trim of front and rear seats if you are supplying fabric, i would say there was reason to be skeptical about quality if anyone was offering to do it much cheaper than that
    Jan 2017
    Does anyone know where I can get the 2x 3pin and 1x 2 pin plugs for the ecu. the wiring on mine is terrible and just a soldered mess. cheers
    Non-member tubbyG's Avatar
    Dec 2010
    Quote Originally Posted by dmiller1 View Post
    You should probably start your own thread
    Is it the complete wiring to the Aei you are after or just the plugs? I have some tdc & knock sensor wiring leftover from when I converted to nodiz, I will have a rummage and see what I have and if its any use
    Jan 2017
    Quote Originally Posted by tubbyG View Post
    Thanks for getting back to me. Yeh a new thread might be a good idea. I am certainly getting my 15 quids worth.
    I dont need the cables just new pins for the connectors ( if they are even available) if not,new connectors with pins so i can solder onto wiring and remake ends off. Thanks
    Dublin/Ireland
    https://www.simtekuk.co.uk/index.php.../?k=:8:126960:
    a very good supplier.....especially when i went EFI.
    ignition ones are delphi .....i think!!
    Likes tubbyG liked this post
    Jan 2017
    let you see what im dealing with Name:  20170927_174303-747x1328.jpg
