Results 1 to 9 of 9
    Jun 2014
    ignition barrel staying on?
    Hello all just had a strange issue car is starting and staying on but still trying to turn over. I have to turn the key back abit to stop this issue. Any way to fix as i guess its a spring inside gone inside?
    Thanks
    Re: ignition barrel staying on?
    It's a new barrel time I'm afraid. not a hard job to change over.
    Jun 2014
    Do I have to remove much of the dash..? Thanks
    I've never had to change a barrel but I know you can get to it by simply removing the lower plastic cowling (2 screws I think)
    Lower cowl off, 4 bolts hold the column, loosen to pull the column down. Put the key in and turn to either position 1 or 2, I think 2. There's 2 small rectangular pronges underneath that need pushing in simultaneously with long nose pliers and it will then slide out.
    Jun 2014
    all sorted thanks
    Excellent. Was my method correct?
    Jun 2014
    Yes it was
    Likes Trevhib liked this post
