Results 1 to 8 of 8
    Non-member Brizza's Avatar
    Aug 2010
    Penistone
    Hi all, parts required...
    Hi all, after a little hiatus I am getting my ready for my wedding in August.
    I need the following parts but can't get hold of Mike @ GT Turbo spares.
    *the item that is attached to the front of the subframe that is a steady?
    *baffled sump
    *rear 1/4 window rubbers that go on the hinges
    *OEM ph2 header tank
    *new clear fogs
    Can anyone help?
    Re: Hi all, parts required...
    Ey up Briz. Where you been?
    Mike normally floats about on here so hopefully he will pop up. I think I might have a brand new ph2 header tank.
    Matt
    Aug 2010
    Penistone
    Hi Matt, I've been keeping a low profile busy with work and home stuff, its amazing how life flies by when your busy and sadly other things have to take a back seat. My 5 has been in the garage all this time and I've managed to get a few bits sorted for the wedding with it, I'm just looking at some bits to fresh it up. the sump looks to have seen better days so deffo needs replacing I think, as does the mount that bolts on to the subframe that steadies the gearbox.
    I've been trying to get hold of mike but I think he's been uncontactable recently.
    Hope all is well with yourself? its been a while since I've been on here and really seem quiet! I was unable to get any questions/requests answered on facebook so thought I'd rejoin for the sake of 15 quid. I've decided its time to get my 5 back to its glory again
    I Can still get clear fogs from valeo. £79.99 for the pair plus delivery
    Header tanks can still be got from Renault, think they are around the £30 mark, you can get bolk header tanks from mister-autos if they still got them.
    Last set of rear side window rubbers went on ebay for £150 + delivery
    Aug 2010
    Penistone
    Cheers! any ideas on the gearbox steady?
    I saw your post on Facebook about that, it was the bracket part not the actual metal attachment to the gearbox it self. I had a quick look online to see if there was any new ones to not much luck. Its not something which I have ever removed from the subframes. As said think best bet is Mike (if can get in contact), CGB (current prices it will be about £400) or try Carlos (carl hyde) on ebay, has a lot of items but not sure if he will have that.
    Alright Brizz
    Congrats on (and best luck for) the wedding. Hope you get the car back on the road in time. You'll find things are harder to get hold of and more expensive these days but it's doable.
    Aug 2010
    Penistone
    Thanks for the help guys, I will try mike later as I've got a shopping list at the mo!
    Likes Matt Cole liked this post
