Results 1 to 6 of 6
    Farnborough
    Rear Brake Compensator
    Brand new Bendix rear brake compensator. Just realised I have 3 so this one is up for grabs. £95 posted to mainland UK which is cheaper that the usual sources will charge you complete with the spring.
    Oct 2004
    Somerset
    Re: Rear Brake Compensator
    Ill take it mark...
    Farnborough
    PM coming your way and Welcome back Matty.
    Apr 2014
    Mark, can you please post the part number for this?
    TIA.
    Farnborough
    Matt, Part number is a Bendix 311593b. Have a look at this site for the other part numbers it crosses over to.
    http://www.yoyopart.com/oem/5538371/bendix-311593b.html
    If you scroll to the bottom it confirms it's the correct one for the GT Turbo. In fact all 3 that I have are the same part number.
    https://www.rtoc.org/boards/showthrea...ar+compensator
    Lots been discussed on brake compensators and part numbers
