Results 1 to 6 of 6
    Apr 2013
    Dublin
    HELP ..Front indicators + Fogs stopped working ??
    any ideas lads ?
    Re: HELP ..Front indicators + Fogs stopped working ??
    Front fogs the wiring goes from drivers sides across with a joining wire. Have you checked the relays behind the drivers side light. I take it the repeaters are not working as well?
    Apr 2013
    Dublin
    thanks mate
    I only have the rear indicators working - i've lost both on front and side..
    strange that I've lost both - is there 2 relays - one for each side?
    You have 2 relays behind drivers side. The one on the passenger side is for the horn. Other thing to check is the connector block which comes out from the drivers chassis leg as that's where the wiring comes through to the front.
    Apr 2013
    Dublin
    thanks mate
    Jul 2014
    My indicator on the passenger side keeps playing up...
    Because old..
